Old 06-06-2013, 10:52 AM   #1
Oxford14Stang
Oxford14Stang's Avatar
Default dynoing the car today
Getting her dynoed to get baseline numbers before the CAI & tune arrive tomorrow. Right now it has magna flow axle back and replaced stock 3.31 gears for 3.55s. Neither of which should make any differences if at all. Any guesses of the numbers?
2014 Oxford White 5.0 MT-82
Oxford14Stang is offline   Reply With Quote
Old 06-06-2013, 11:25 AM   #2
46Tbird
46Tbird's Avatar
Old 06-06-2013, 11:26 AM   #3
Auto or stick and where you dynoing
Old 06-06-2013, 11:27 AM   #4
Oxford14Stang
Stick, dynoing at Gear heads performance in Arlington. Your numbers in your signature, were those stock?
Old 06-06-2013, 12:02 PM   #5
Old 06-06-2013, 01:34 PM   #6
Default Re: dynoing the car today
Yep only mod was gt500 axle backs.
I say 383/379
Old 06-06-2013, 12:10 PM   #7
With the humidity and heat this morning, your STD will be around 380/370 +/- 5 for both
SAE numbers will be corrected to around 375/365 +/- 5
My dyno numbers in my sig were only GT500 ABs and 3.55s. You should be pretty damn close to what I made.
Old 06-06-2013, 12:17 PM   #8
Originally Posted by DirtyD View Post
With the humidity and heat this morning, your STD will be around 370/360 +/- 5 for both
SAE numbers are always lower then STD numbers.
Old 06-06-2013, 12:25 PM   #9
Nevermind, you are correct. I was thinking unfactored. My bad.
Old 06-06-2013, 12:32 PM   #10
Oxford14Stang
Let's hope so
Old 06-06-2013, 02:35 PM   #11
What is with your obsession with the settings on the numbers? I don't get it. The only numbers that matter are on the track. Dyno numbers do not equate performance numbers, it's simply peak numbers. The dyno is only a tool to tune a car not measure performance. I don't get this younger generations obsession with peak numbers.
Old 06-06-2013, 02:47 PM   #12
Well the results are in. 358hp, 338tq with 74 degrees outside And 70% humidity -- must add that's just with 3.55 gears and magna flow axle back .. CAI & Tune will arrive and be put on the car tomorrow.
Dang, those are almost numbers from an Auto. Did they give you a print out of the dyno graph? Wonder what type of dyno it is.
All I did was just give him an estimate in both corrected forms. That's all. He asked about PEAK numbers, I answered his question. I know the track is where you put those numbers to the test, troll.
I don't get why you get so damn uptight about it.
Old 06-06-2013, 03:11 PM   #13
I'm not uptight about it, you arguement just doesn't make any sense. Grilling someone over STD or SAE doesn't really matter. Depending on the air, temp, humidity or whatever else those numbers are nullified on any given day. Manual or auto, big convertor/small convertor etc. There is so many ways that can be manipulated it's crazy.
What matters is performance and having all the parts in a set up that work together in a efficient manner. A car make numbers to the moon, but it doesn't use them with the proper powerband, gearing etc for how it's intended on being used, then the numbers are useless.
How many times have you seen a car make really low numbers, but down some crazy ET times at the track? It's because the combo works together.
The same can be said for some high number dyno queens - why is it they can spin the rollers to a crazy number, but yet they get out on the street and get drug dirty by cars making much less? Because the setup doesn't work.
That is the point I'm making to you. The ONLY numbers that matter on a dyno is the A/F while tuning.
Old 06-06-2013, 03:21 PM   #14
Dude, what fucking argument are you talking about? I simple typed my guesses to his dyno numbers. Who gives a flying shit if I put down both STD and SAE? I wasn't grilling anyone. I'm over that fucking shit from the other day. But obvious you aren't because you bring it up every god damn chance you get. It's getting really fucking old.
Old 06-06-2013, 05:14 PM   #15
White_lightning
I agree and disagree with you. a dyno is like you said a Tool...
I guess its the bench racer in me, but you can take a car making 900 rwhp with a very peaky power band and a car with 900 rwhp with a HUGE powerband and the one car will walk away from the other. That's why normally a 600 rwhp nitrous car will pull on a 600 rwhp Blower car. Its all in the power band.
since I like to see the delta.. I normally dyno my car at the same place.. and use SAE numbers because they are normally Lower.. most of the guys using STD numbers are to over inflate their numbers... I couldn't give a fuck about setting a record.. I want to know where my powerband starts and stops.
2008 C6 coupe BPU++ Tuned by sam.
White_lightning is offline   Reply With Quote
