07-08-2013, 10:43 AM
#61
Originally Posted by re-rx7
Stock to stock your big ass wheels vs my stock 18's will make a difference.
No, just no.
His wheels weight as much as your stock 18s do. The only thing Steve would be lacking in would be cornering ability as his sidewall is much shorter than yours, but it would be made up by the fact his tires have a full 2-3 inches more surface contact to the pavement than your 18s have.
rotating mass > static/unsprung (dead) mass all day long.
#62
I know. Had my civic on stock 15's then decided to go to 17's. I didnt notice it when i went up to the 17's but when I went back to 15's HOLY SHIT! The difference was huge. Granted with the lower power output of the civic the difference would be greater but the same should hold true on a more powerful car no matter.
Why make skinny wheels if there is not a need and they do not make a differnce? Plus the contact patch of the wider tires creates more friction on the surface of the road. This also soaks up some power. Take a wheel barrow put a skinny tire on say a 235 and push it. Then put a 275 or 295 on there and see if there is a difference in effort to push it.
07-08-2013, 10:54 AM
#63
Originally Posted by DirtyD
No, just no.
What about my 18's?
07-08-2013, 10:56 AM
#64
Originally Posted by BLK2012GT
What about my 18's?
your a gd example of my theory. Theory.
07-08-2013, 10:59 AM
#65
No, just no.
Exactly.
Just...stop.
07-08-2013, 11:03 AM
#66
Originally Posted by Steve
Just...stop.
If Im wrong prove it.
Explain how Blck2012gt picked up power?
07-08-2013, 11:07 AM
#67
Ford puts tiny tires on the car to get the gas mileage CAFE standards up. 235s on a 3600lb car with 400rwhp? Please. That shit is damned near negligent homicide. Tire grip should be the first thing you think about when building up your performance car, not gas mileage or 'soaking up' power. My wheels may be heavy-ish, but they're not as heavy as my stock Brembo wheels and Pirellis were. And when I need grip, I got it.
#68
Yes I picked up power but with the same wheels if I take them to the track I would run slower times with them cause of no traction then I would with my old 20's. Now my new 18's is a different story. lol
07-08-2013, 11:08 AM
#69
dyno reading ≠ grip
07-08-2013, 11:16 AM
#70
I agree with your statement and the negligent homicide part had me rolling. lol From a roll stock to stock the stock rim car will be faster then same car with 20's and wider tires. No?
07-08-2013, 11:18 AM
#71
I doubt it cause I broke those 235's loose going hwy speeds when I slammed it in 3rd.
07-08-2013, 11:21 AM
#72
A wider contact patch doesn't "soak up" power. It just creates a higher friction force of which the car has to overcome. The power output is the same. As long as the wheels being compared are close to the same overall diameter, the effective gear ratio will be unchanged, thus negligible tq "loss."
Your wheel barrow example doesn't apply here. They are designed to work with a skinny tire to provide the ability to lean as they turn/pivot.
A wagon would be a better example to compare with a car.
A larger tire gives you a larger area in which to spread the load. This means the object will handle better because the weight ir more distributed on the tire surface, making it handle more precisely. The only difference having a 235 on a wheel barrow would make would be the rolling resistance, but once it is rolling, you wouldn't be able to tell the 235 and 295 apart.
07-08-2013, 11:23 AM
#73
How the fuck did we get to how stock rims are better then 20" rims from whats the difference in year models?
07-08-2013, 11:24 AM
#74
If the entire wheel+tire setup for the 20s is heavier than the stock setup, then yes, stock wheels will be faster. If the 20s are lighter, the car with those wheels will likely be faster.
Rotating mass if a big deal. The less weight you have to rotate means the motor will rev faster since the work being supplied to turn it is less, giving the motor more power to push itself forward and accelerate.
07-08-2013, 11:25 AM
#75
Same reason as every other thread derailment.
ADD.
