Old 04-05-2013, 10:06 AM   #1
Kosovobandit
http://www.svtperformance.com/forums...no-procal.html
Link to my number on Airraid vs stock box in STD.
Kosovobandit is offline   Reply With Quote
Old 04-05-2013, 11:09 AM   #2
TrueStreetTim
DFW5.0s Preferred Vendor
TrueStreetTim's Avatar
Thanks for the link! A perfect addition!
TrueStreetTim is offline   Reply With Quote
Old 04-05-2013, 11:53 AM   #3
Dan12GT
Dan12GT's Avatar
Default CAI Throwdown
You also have to consider the weather conditions. I very well may have gained HP. It was a cold day on the stock dyno so much denser air. The 2nd dyno I had was significantly warmer outside so that very well might account for the HP number to "stay the same" when in fact it probably went up. I think my stock numbers might look a bit embellished due to the cool air. There are soooo many factors that affect dyno numbers it's almost impossible to get a 100% accurate reading. The only real way to do true testing is with the same dyno, the same weather conditions, the same car, and the only changing factor be the intake. Even then not every car will respond the same.
Old 04-05-2013, 12:08 PM   #4
TrueStreetMotorSports.com
to add more fuel to the fire, I have seen weather in the morning 50* and after install and lunch (the fat kids got to eat) 72*. Same day comparison can also be a little off as well
True Street MotorSports
901 N McDonald St Suite 100
McKinney TX 75069
972.542.9886
TrueStreetMotorSports.com is offline   Reply With Quote
Old 04-05-2013, 12:28 PM   #5
This is true, and also why I don't put much trust in STD numbers, because they tend to not be as comparable when it comes to different atmospheric conditions during different dyno sessions. SAE is better for comparison purposes when it comes to trying to "disregard" weather changes.
Old 04-05-2013, 12:17 PM   #6
Kosovobandit
That is why with the test I did it was the same day, temp, car, dyno, and the time took about an hour. There was also no fan on the car at the time and the door was closed to the dyno area.
Old 04-05-2013, 12:44 PM   #7
Luke
Luke's Avatar
Track numbers > dyno numbers!
Old 04-07-2013, 03:07 PM   #8
Kosovobandit
Track result are just as subjective as dyno results. Things like: Temp, track prep, tire, driver, shift points, ect all come into play.
Old 04-17-2013, 10:55 PM   #9
Justin@VMP
Our auto 5.0 car ran faster at the track with a stock airbox, cold dense air makes for harder hit out of the hole. However my 5.0l tvs kits all come with JLT intakes...more flow more power.
Justin@VMP is offline   Reply With Quote
Old 04-17-2013, 10:59 PM   #10
^If this guy doesn't know, no one does!
Old 04-17-2013, 11:43 PM   #11
Whoa, when did you get here, Justin? Nice to see you around.
