Old 06-30-2013, 10:25 PM   #31
Rebelracer568
Rebelracer568's Avatar
What's the cost to convert to e85
Rebelracer568 is offline   Reply With Quote
Old 06-30-2013, 10:31 PM   #32
Zeek
$250 for 47# injectors and whatever your tuner charges
Zeek is offline   Reply With Quote
Old 06-30-2013, 10:33 PM   #33
Rebelracer568
That's not bad. Something to think about for future.
Old 06-30-2013, 11:04 PM   #34
Oxford14Stang
Oxford14Stang's Avatar
Yeah, since it makes it "safer" when I buy a daily, I will highly consider it. I've heard race gas, like 103 is bad for these cars. Didn't seem right, anything on this?
2014 Oxford White 5.0 MT-82
Oxford14Stang is offline   Reply With Quote
Old 07-01-2013, 12:00 AM   #35
When I pick up a daily, my car will for sure be getting the corn conversion.
Old 07-01-2013, 02:37 AM   #36
Once there are more stations I might think about it and only if I will have the ability to switch back and forth. I don't want to be driving and get stranded because there is no corn close. And prolly only once I have boost
Old 07-01-2013, 09:06 AM   #37
Originally Posted by 04sleeper View Post
Some bad information in here. Just figure I would clear a few things up. E85 is perfectly fine with the stock lines. It will not degrade the small amount of rubber at all.
You WILL gain with E85. Even if it is only a few HP, the safety margin alone and not being on the verge of detonation is worth it IMO. It was the first mod I did to my car.
With these newer High Compression motors, high octane and good fuel is essential for longevity! Especially once tuned and pushing more timing than the factory has designed it for. E85 is a safeguard against detonation. No #8 failures here!
If yor even close to detonation or experiencing it on 93 then you need a new tuner.
Old 07-01-2013, 09:16 AM   #38
With these high compression motors all it takes is a bad tank of gas which is much easier to get in DFW than you think. Kevin has forgotten more about tuning than you know. When he offers input, you should listen.
Old 07-01-2013, 10:00 AM   #39
I haven't yet heard of a single E85 station here in DFW that had anything under E85 that measured under E80. But like Midnight said, most of the station will exceed E85, since there could be some deep shit go down by someone losing their car by a tank of E85 that doesn't pass the standards of minimum 85% volume +/- some percentage.
Old 07-01-2013, 10:29 AM   #40
Bearded Banger
Bearded Banger's Avatar
E85 is liquid gold. I assure you Kevin (04 Sleeper) knows what he's talking about.
My 04 cobra is on corn, and The boss is next.
Bearded Banger is offline   Reply With Quote
Old 07-01-2013, 10:47 AM   #41
Rebelracer568
Can you run racing fuel in these cars to help eliminate the detonation?
Old 07-01-2013, 02:49 PM   #42
I'm switching back to pump gas and adding torco to mine. My mpg sucked cause of e85. Even though I don't drive it that much, going to lewisville from frisco and back I use 1/4 of a tank. That's BS. Plus the drivability on the car sucked with e85. So I don't know if changing to 13:1 compression had anything to do with the drivability issue but I will not be running e85 again.
Old 07-01-2013, 03:59 PM   #43
Bearded Banger
Being able to get 105 octane at the pump for the cost compared to a race gas cost is a huge factor.
You get nearly all the benefits for a hell of a lot cheaper. On top of that its more available.
No goes E85 for the mpgs. That's a well known fact. I wanted to protection level it offers. I wouldn't throw your drivo issues at e85 and walk away. You may have issues on a 93/torco blend too. How are you going to consistently get the octane rating your engine needs blending torco and 93? Serious question. Curious as to what your plan is. 10 gallons one can situation? I don't trust that.
Old 07-01-2013, 04:13 PM   #44
The same goes for E85 you really never know if that is really E85. Its hit and miss. When I had my rx7 I premixed. Oil and that is and had a pretty gd ratio worked out.
Old 07-01-2013, 04:19 PM   #45
Bearded Banger
I have a test kit. I know exactly what I get.
