| Performance Post anything performance related to your Mustang |
| Sponsored Ads |
02-27-2013, 12:03 PM
#31
3.31 vs 3.73
Originally Posted by pohnjarker
i have 3.73s but plan on going down to 3.27 since i went boost
We should just swap rear ends then hahaha.
03-01-2013, 06:51 AM
#32
shoot, if i was home, i dont see a problem with that.
i'll be adding in an Eaton Limited Slip Differential as well since they will have the rear end opened for the gears.
03-02-2013, 08:47 PM
#33
<--keeping my 3.15's....
03-03-2013, 05:51 PM
#34
This is kind of what I feel I might do next. I rarely have the car at 120+ and I am not going boosted or big power anytime soon, so I wouldn't mind ditching my 3.31s for 3.73s. No Jeff I don't want your 4.10s!
03-03-2013, 05:54 PM
#35
Want my 4.10's?
03-03-2013, 06:42 PM
#36
Originally Posted by blk2012gt
want my 4.10's?
nope!
03-03-2013, 07:20 PM
#37
nope!
Yes foo
03-03-2013, 08:18 PM
#38
Have any of you guys arena difference when running the 2 cars against each other? I really haven't been able to find much on this. Will the cars run close or will one walk away?
there are a lot of different factors that come into play besides just final drive gear ratio.
the difference between the two is probably not that noticeable.
2013 Performance White Boss 302
-Stock
2002 Mineral Gray GT
-VT engines Stage 2 N/A cams, full SLP exhaust, 4.10 gear...etc.
03-03-2013, 09:38 PM
#39
3.31 vs 3.73
Even a couple hundred RPM over 3-4 gears could mean the difference.
03-03-2013, 09:56 PM
#40
Originally Posted by Steve
Have you had your car to the track yet? It seems a lot of people running the 3.73's complain about banging the rev limiter before hitting the traps, defintely more so with the cars making more than stock power.
I have been to the track with a 3:73 car that is non Brembo and no tune just a cold air/horrible driver. I do not hit the limiter and shift at 6,800-7,000. The non brembo cars with the 245/45 19 is a 27.7 inch tall tire which helps. The brembo guys have a 255/40 19 which is a 27 inch tall tire. That is part of the reason for the rev limiter issue. The 3:73 do get you in the band nicely.
