Old 11-25-2012, 09:54 PM   #16
Camber aren't really needed unless you intend to do some road racing, requiring a good amount of adjustability in your caster and camber. I asked the same question, and that's the answer I got. If you are really just going to be street driving your car, GT500 mounts and camber bolts are really all you need.
I still don't how your brand new mounts went bad...
Old 11-25-2012, 10:21 PM   #17
Originally Posted by hatchttu View Post
What do you guys think about the J&M camber plates, I assume these are the replacements for the GT500 strut mounts as in I wouldn't need to buy anything else.
http://www.latemodelrestoration.com/...-Camber-Plates
I have the Maximum Motorsports plates and they work great.
Old 11-26-2012, 10:20 AM   #18
hatchttu
hatchttu's Avatar
Well, I thought I would give a little update. I am almost embarrassed to say it. I checked every bolt to make sure they were tight and they were. The only one I could never get to on the car was the top nut that holds the strut mount on the strut. When I assembled them when I used a socket it would just turn the whole shaft so I had to get a box wrench on the big nut and a small socket on the top of the shaft to get it tight. SO yesterday I picked up one of those pass thru sockets from Lowes (had to get 22mm) so I could get it on the big nut but still be able to keep the shaft from turning.
Last night I dropped that on, held it with a wrench, put the small socket on the top of the shaft and got it to turn just a touch, maybe 1/8 of a turn at most. Well, on the way to work this morning the ride was silent, no sounds at all. So I guess that nut had come loose just enough to let things hop around.
Thanks for the knowledge and advice.
hatchttu is offline   Reply With Quote
Old 11-26-2012, 11:50 AM   #19
Glad to hear you got it worked out.
Old 11-26-2012, 12:09 PM   #20
ah yes that bolt is a bitch. took me forever to get them off and then back on again since you can only turn it so much...
