Old 08-29-2014, 10:56 AM   #16
Shiftybusiness
Originally Posted by Reaper View Post
They ended up cutting me a deal at $85 because it took longer than planned. And found out my car isn't leveled from the factory which is always awesome to hear...
I'm at Dallas Frame & Alignment now and they said the same thing that it's not level. Basically they said adjustable coilovers are the only solution. With as much forum browsing I've done over the last year I've never heard of this. They also said the last 4 Mustangs had the same problem.
Shiftybusiness is offline   Reply With Quote
Old 08-29-2014, 11:57 AM   #17
Courtesy Flush
They did my alignment in 2012 when i installed new struts/shocks & springs.
No mention of the car not being level.
Courtesy Flush is offline   Reply With Quote
Old 08-29-2014, 02:59 PM   #18
Shiftybusiness
You might not have that problem. At least they were able to get me aligned.
Old 08-29-2014, 05:12 PM   #19
Reaper
Reaper's Avatar
Yeah I stopped by ford on the way home. The guy just blew it off pretty much assuming it was within tolerance. It's whatever I guess... Yeah coil overs is a solution. Also they said they bend the sway bar sometimes. Or get a 3 way adjustable sway bar and off set the holes.
Reaper is offline   Reply With Quote
Old 08-29-2014, 07:04 PM   #20
Shiftybusiness
Yea that's exactly what they told me.
Old 09-24-2014, 09:35 PM   #21
Reaper
Reaper's Avatar
Originally Posted by NAVAG View Post
Muffler King in Garland. Kevin does good alignments on lowered cars.
Are you talking about Bill the Muffler King on 11118 Garland Rd?
Old 09-24-2014, 11:40 PM   #22
TwoQuack
TwoQuack's Avatar
COBB in Plano does race alignment and car balancing.
TwoQuack is offline   Reply With Quote
Old 09-26-2014, 11:41 AM   #23
NAVAG
NAVAG's Avatar
Yes. Call and ask for Kevin. He'll take good care of you. He got mine within spec without camber bolts. I need to go back since its been about a year. This time I'll bring a set of camber bolts with me.
2016 RACE RED GT PREMIUM
previous stangs
2013 BLACK GT PREMIUM
1989 GRAY/SILVER AUTO GT
1988 RED GT
1989 WHITE LX 5.0 HATCH
NAVAG is offline   Reply With Quote
Old 01-18-2015, 12:59 PM   #24
GreggASmith
GIO Tire Shop on Cooper in Arlington did mine after I installed the Steeda springs. The only thing that needed adjustment was the toe.
The place doesn't look super impressive from the curb, but every employee seems to own a drift car or an autocross bandit. They do good work.
2012 Boss 302, Steeda Springs, Aluminum driveshaft, etc, etc...
GreggASmith is offline   Reply With Quote
Old 01-18-2015, 02:11 PM   #25
NAVAG
NAVAG's Avatar
I went back to Muffler King a couple of months ago when I got my new wheels. I also added a new set of Koni Orange shocks and struts recently and I knew the front end would need to be adjusted.
The camber was waaaaay off after I put everything together. The stance was so bad I was expecting to hear some loud-ass woofers and see a fart-can muffler sticking out of the back. Kevin at MK got everything back in spec and didn't charge that much - less than $75.
Also what I like about that place is that they always seem have a 65-68 Pony on a lift doing work on it when I go there. It also isn't much to look at on the outside and it's in Garland, Texas...and it may look like Zombies destroyed it but it's just Garland.
previous stangs
1988 RED GT
Old 02-03-2015, 03:14 PM   #26
TwoQuack
TwoQuack's Avatar
COBB tuning in Plano has the right tools for 4 wheel alignment and camber adjustment.
Old 02-05-2015, 05:28 PM   #27
GunsUp
GunsUp's Avatar
NTB at coit at bush right by the Friday night meet has an alignment machine for lowered cars. My buddy is the manager there. Said they get all kinds of hellaflush cars there
GunsUp is offline   Reply With Quote
Old 02-05-2015, 09:43 PM   #28
Lucky13
Lucky13's Avatar
Get a camber gauge from Maximum Motorsports for 75 bucks, some string and jackstands and knock it out. Easy. There are links all over the place. Level a place in the garage and do it. Patience required but a shit ton cheaper than alignments all the time if you're dicking around with camber. My $0.02.
2013 GT 20x10 Niche Targas Nitto Invos, Koni Yellow struts, Eibach springs, BMR adj Pbar, Pypes Pype Bombs, Tune
Lucky13 is offline   Reply With Quote
