01-04-2013, 04:02 PM
#151
DFW5.0s Preferred Vendor
Originally Posted by Steve
Ok, so go fuck his arm off then. Thats even worse! Lol
I'm starting to think you just have a strange affinity towards my fantastic breed of humans.
01-04-2013, 04:41 PM
#152
I have a small penis
I think he wants to see if the carpet matches the drapes. My advice is never put down your drink next to Steve. You might wake up a changed man.
01-06-2013, 12:02 PM
#153
(Crank pulley size / Blower pulley size X step up ratio) X max rpm= impeller speed
Bold items are simply to separate the math
I'm assuming a lot here as I don't have all your specs. So your roughly 630whp? I'll also assume you've got headers & full exhaust?
P1SC-1's max impeller (max efficiency) speed is 65k. It should also be a 4.1 gear (step-up) ratio. Your blower pulley roughly a 3.60? And crank pulley a 7.5.
So [I](Crank pulley size / Blower pulley size x step up ratio) x max rpm= 61.5k impeller speed @ 7,200rpm. So your around 95% the max efficiency.
To see that kind of power on a P1 I'm guessing the car is around 12-14psi. What kind of psi are you seeing?
Yes that is what size the pulleys are. Thanks for your help.
2011 Mustang 5.0. Brembo, JBA longtubes, H-pipe, Flowmaster Axleback, Procharger. 637rwhp, 499rwtq
01-06-2013, 02:50 PM
#154
So the p1 is pretty much maxed out at 630ish? Fuck.
01-06-2013, 03:06 PM
#155
Feel lucky that number was achieved. The P1 an entry level head unit and I've seen it implode on itself at 440rw.
01-06-2013, 03:43 PM
#156
Thats enough of this implode talk. I won't be able to sleep at night worrying about it.
01-06-2013, 03:46 PM
#157
Haha, sorry. You can ask Blownaltered about his P1sc expierence. Once he stops swearing like a sailor from the anger of it, I'm sure you will understand.
01-07-2013, 01:25 AM
#158
Definitely not a fan of the p1sc line from Procharger. Sad thing is I didn't even over spin it. There was still room left when it ate itself.
