10-06-2014, 08:01 PM
Are stock cars camber adjustable?
Had a alignment after I hit a rock that messed up my rim now firestone says camber is off and no way to adjust they recommend new strut mounts and shocks.
10-06-2014, 10:29 PM
I wanna say they aren't. Not totally sure.
10-07-2014, 12:08 AM
They are not. Camber bolts
2014 GT Track Pack (300A) Black/Black, Recaros, Eibach Pro-kit, Koni adj (yellows), MM camber plates, Whiteline PHB & bracket, Whiteline adj rear sway,Hawk HP+, J+M SS lines,FRPP brake ducts, GT500 AB, 275/35/18 BFG Rivals on 18x10x43 D-force LTWs, Tint and blackout.
10-07-2014, 09:39 AM
So before replacing shocks and strut mounts anything I should check for like control arms etc to make sure firestones not pulling a upsell?
10-07-2014, 02:36 PM
Not sure. I recommend Dallas frame and alignment to get suspension work done. I just took my springs, shocks, and struts of my 2014 with 7k miles if you're interested. Which wheel did u hit?
2014 Black Premium GT
Recaros, JLT CAI, LP H-pipe, Corsa quad exhaust w/ GT500 valence, Lund tune, Eibach sportline springs, Koni yellows, BMR red panhard bar and LCAs, MGW shifter, RTR 19X9.5 wheels, Billet upper grill, Roush high flow lower grill, Cervini stalker spoiler, tint all around wrapped in matte black
10-07-2014, 04:32 PM
passenger side front destroyed a forgestar rim.
01-18-2015, 12:54 PM
The factory upper strut mount is a weak link. One of mine failed at 15,000 miles with no impacts, no pot holes, nothing. I actually have extras in my garage! If you want to change your own, it is a very easy job and DOES NOT require a spring compressor or any fancy tools.
From the factory, you can get TINY camber adjustment from the tolerances in the four holes in the shock tower, but there are no actual adjustments.
2012 Boss 302, Steeda Springs, Aluminum driveshaft, etc, etc...
01-18-2015, 02:22 PM
I got Camber Bolts. They worked.
But if anyone is planning on lowering their car for the first time should know that springs and panhard bar aren't enough. buy the following parts and only have to work on the car one time as opposed to several times every time one of the factory POS parts fail.
Upper Strut Mounts (GT500 are the most cost effective)
Shocks and Struts
Camber Bolts
I installed Springs and then heard a popping noise coming from the front a couple of months later and had to replace the upper strut mounts. Stock ones fell apart when taking them back off the struts.
GT500 Upper strut Mounts won't work on 11-14 struts so I had to order new struts for 05-10.
Rear end got loud a few months later and I had to replace the rear shocks.
2016 RACE RED GT PREMIUM
previous stangs
2013 BLACK GT PREMIUM
1989 GRAY/SILVER AUTO GT
1988 RED GT
1989 WHITE LX 5.0 HATCH
03-22-2015, 05:32 PM
Strut Mounts
The Steeda Adjustable Heavy Duty Caster Camber Plates work great. I just lowered mine with them and need nothing else for alignment.
