Old 03-01-2014, 10:37 AM   #16
JDMLOL
JDMLOL's Avatar
Originally Posted by NikkiDawson View Post
I already have my eyes set on a bama, so what brand midpipe would you recommend?
Lethal performance is a good one. It is all one piece so there are no issues of having potentially leaky cat delete sections.
Old 03-01-2014, 07:06 PM   #17
Shiftybusiness
Also, people have been asking if I use 93 octane.[/QUOTE]
I use premium fuel only, the price difference is not that much per tank and when you use the cheap stuff you loose a little bit of power about 20hp because the computer takes out timing to prevent detonation. Run a tank of 93 and see if you notice a difference. It shouldn't hurt anything using 87 but I don't see the point also if you get a tune you will probably need to run 91-93 octane anyway.
Shiftybusiness is offline   Reply With Quote
Old 03-01-2014, 07:39 PM   #18
I use premium fuel only, the price difference is not that much per tank and when you use the cheap stuff you loose a little bit of power about 20hp because the computer takes out timing to prevent detonation. Run a tank of 93 and see if you notice a difference. It shouldn't hurt anything using 87 but I don't see the point also if you get a tune you will probably need to run 91-93 octane anyway.[/QUOTE]
I can get into a lengthy discussion about all that.....
Old 03-01-2014, 08:56 PM   #19
Check out VMP tuning as well
Old 03-02-2014, 09:51 PM   #20
Boss949
Boss949's Avatar
Shaun Perry at AED is one of the best Tuners in the country for Mustangs.
http://www.advancedenginedevelopment.com/contact-us.
Ford Racing X Pipe is very good fit.
2013 Boss 302 PW, Recaro, Torsen, AED tune, Airaid CAI, MGW, Hotchkis Springs/LCA, Whiteline Relo, CHE K Member w/Torque Limiters, Griggs Torque Arm Kit, T/A rear girdle, Kenny Brown Pan Hard Bar, Whiteline Tranny Bushing, JPC Linelock, JPC stainless clutch line, MT ET Street Radials (when needed), , 2013 GT500 Quad Axle Backs, Kooks LT 1 3/4, O/R X Pipe, Resonator Delete, JPC Line Lock,JPC Clutch Line.
Boss949 is offline   Reply With Quote
