Old 12-16-2013, 02:06 AM   #1
Le5oh
Default Exhaust leak
No matter which way i turn and tighten the factory exhaust clamps on my x pipe. It still contuines to have a leak. Any exhaust clamps recommended other then factory?
Le5oh is offline   Reply With Quote
Old 12-16-2013, 08:38 AM   #2
fordplay
High temp rtv .. or they make large band clamps that many people have said work well
fordplay is offline   Reply With Quote
Old 12-16-2013, 11:26 AM   #3
lolvtec
Honestly a forum member gave me a pro tip. Rather than messy rtv silicone you can go to autozone or oreillys and get aluminum looking exhaust repair tape.. just wrap the joint and then clamp over the tape. Completely solved my leak issues.
lolvtec is offline   Reply With Quote
Old 12-16-2013, 03:17 PM   #4
Slowstang1_jgw
Did you cut the tabs so you can move them around?
I had the same problem, but turned the clamps around.
Slowstang1_jgw is offline   Reply With Quote
Old 12-17-2013, 08:14 AM   #5
fordplay
I like the tape idea better than silicone, never thought of that. And better looking than the giant band clamps
Old 12-17-2013, 10:37 AM   #6
I just installed 3 3" band clamps on my H-pipe last night. All 3 are leaking now after being tightened down all the way.
So I'm just going to have to either weld the cat deletes to the H-pipe, which I really don't want to do in order to keep the system modular.
But I will get the middle crossover of the H-pipe welded together.
Old 12-17-2013, 04:40 PM   #7
Le5oh
DirtyD, That sucks.... I miss the days of 2 exhaust flanges welded on, a gasket and 2 or 3 bolts...
Old 12-17-2013, 04:54 PM   #8
It happens. I wanted to get it put on, but I probably should've waited longer to line up someone to weld it up after install. Oh well. Live and learn.
Old 12-19-2013, 11:33 AM   #9
Ya I am wonder what kinda of head aches I will run into with the BBK deletes when I put them on. I was definitely considering 3" band clamps at a minimum.
Curious now that I look at it. Were the band clamps 3" in diameter or length?
Old 12-19-2013, 11:39 AM   #10
This is what I was looking at putting on since my piping is 2.75" from the cats back.
http://www.borla.com/products/275_st...rt__18005.html
Old 12-19-2013, 11:57 AM   #11
Those BBK deletes are going to suck to even begin with...just FYI. lol
The clamps were 3" diameter when rolled and tightened. I'm going to pick up some exhaust tape to wrap around the cat to mid-pipe connection then put the clamps back over it. Then I'll have the mid-pipe welded at the crossover.
Old 12-19-2013, 12:00 PM   #12
Ya, I got them for $25 so if they don't work oh well.
Old 12-19-2013, 02:12 PM   #13
Toby
Anyone needing something welded up, give us a call at truestreet. We can mig or tig weld it together no problem.
Old 12-19-2013, 03:18 PM   #14
If you were so fast away, I would definitely make the trip up there. Been wanting to get the car back on the dyno just out of curiosity as well.
What time do y'all open Saturday?
