Go Back   Dallas Fort Worth 5.0 Mustang Club > Sponsors and Vendors > Vorshlag Motorsports
Old 09-19-2013, 10:37 AM   #211
Fair
Project Update for Sept 18, 2013: This is a continuation of our NASA Nationals event write-up (part 2 of 3?). In the previous installment I covered the final week of work, after our ECR test, showing the things we did in the closing moments before NASA Nationals. One thing I forgot to mention (again): it is always a bad idea to make major changes right before a key event. But in this case, I guess it didn't completely blow up in my face? Sure, the car was loose at higher speeds, which made it a real handful to drive at the FAST 3 mile Outer Loop at Miller, but it had a lot more front grip than it ever did before. We just overshot the set-up a bit, which we are rectifying now with a new, 4" shorter splitter.
New 18x11" S197 Wheel Set-up From Vorshlag
Gotta take care of of this first, since a lot of you guys have been asking us for this 11" wide wheel set-up. Vorshlag has been working on various wheel packages for the S197 chassis ever since we bought one back in 2010. We now have a good set-up for using 18x11" wheels at all four corners that we've measured, tested, and perfected. This took a few iterations to get right, with various sets of wheels purchased and used on our TT3 Mustang. There is no magic formula for stuffing maximum wheel widths under any given car - it takes patient measurements, some testing, and carries a risk of buying wheels that might not fit. Like with our 18x10 wheels we made 2.5 years ago (with D-Force) - we had to buck up, spend the money, and just do it.
After a few "well, that almost worked perfectly" iterations we nailed it and have made this product entry for the four wheel 18x11" Forgestar F14 set-up located here. These wheels cannot be rotated front to rear, as they have vastly different offsets on each axle. That's just the way it works out on an S197 once you go past 10" wheel widths.
Last week we tested and verified the fit of the final iteration of 18x11s on our 2013 GT (which is still for sale if that page says so) with a set of Kumho V710 R-compound tires in 315/35/18, purchased for use by one of our S197 testers, Mark Council. These Kumho 315s are some big muthas! Our black '13 shown here is lowered 2.5" on AST coilovers, has an adjustable WL panhard rod to re-center the axle housing, plus some additional negative camber up front using our camber plates. To go any wider in the rear you need a reverse mounted swaybar (Whiteline) and probably a Watts Link to be safe (we stuffed an 18x12" on the back of our TT3 car this way, very carefully; we have perfected this 18x12" rear wheel set-up for racers as well, after several iterations on our car). To go any wider than an 11" up front you will need a Sawzall. The 18x12" fronts on our TT3 car have had the fenders cut and flared to fit, but the 18x11" works if you get the offset right.
As you can see in these pictures, the 18x11 wheels are close to the edges of the fenders at both ends, but these do fit, even with fat 315mm tires. This set-up has adequate inboard clearance up front and plenty of inboard room out back. It would also work with 295s, 305s or even 285s. We now offer these in our online store.
These are built to order and take from 4-6 weeks, and are perfect for autocross and track use, and maybe even street use if you are so inclined. We have made these in the mesh 14-spoke F14 versions but they would likely also work in their CF5 5-spoke version as well (just a tick heavier). Give us a shout if you are interested.
Prep Work During NASA Nationals
OK, so I got that out of the way. Let's talk about NASA Nationals! In this section I will cover the work we did to the car in the paddock all week. The car was dead nuts reliable, but we still had to do some wrenching over the 5 days we were at Miller, mostly having to do with the 3 sets of tires we used. And we were among the poorer of the TT drivers, with only one set of brand new "sticker" tires used all week. Other folks used 2, 3 and even 4 sets of stickers in TT. Hey, if you've got the money, why not? As we learned the conditions could change at any moment and you might be stuck with a time from an earlier session.
My favorite picture of the Mustang taken at Miller. Brandon did his magic on this one, right after it rained...
First, I have to talk about the track: Miller Motorsports Park is the most amazing facility I've ever raced at (not counting COTA, where we only "hooned around in Cadillacs"). Sorry, NOLA, you guys have an amazing track and grounds, too, but this one has mountains. Literally, every direction you look is filled with picturesque views.
You couldn't TAKE a bad picture here if you tried. Did you see that "wet paddock" picture above? Click it for a super-sized version - Brandon shot some amazing stuff all week. Like the owners at NOLA, the folks at Miller didn't just build a great track, they have amazing buildings and garages, a massive clubhouse, cafes and shops, plus they house and run the Ford Racing school here. There is a kart track, zip line, 900 acre off road park with 90 miles of course, a rock climbing course, a motocross and stadium truck course, and a museum. In one word: Epic
We parked at the far end of the West Paddock. This facility is huge and sits on over 500 acres!
Continued below
Former site sponsor
Fair is offline
Old 09-19-2013, 10:37 AM   #212
Fair
Continued from above
We arrived at the track on Wednesday afternoon at around 4 pm and headed straight to the front office (outside of the gates) to check in. Many folks got there on Monday or even Tuesday to do some testing - we just couldn't afford the extra time away, but probably should have been there to learn this track. Signed a bunch of waivers, got our event shirt and hat, checked in, bought paddock passes for the extra crew we were flying in, and they then promptly sent us on a wild goose chase to the "South Gate" entrance, which was chained and locked. All week. Then I backed the trailer and truck up a very narrow 1/4 mile long entrance road, 3-pointed the rig, then headed to the North gate, which every sane person was entering into the facility.
Vorshlag NASA Nationals Photo and Video Gallery: http://vorshlag.smugmug.com/Racing-E...als-at-Miller/
Once inside (everyone was super nice, btw) we drove the entire length of Miller's paddock looking for an open spot to park... apparently you could reserve a closer parking space or garage for a fee, which we had neglected to do. And the place was packed already, anyway. The small amount of unreserved parking was at the far end of the paddock, where we found a space right next to the grid but still a good distance from all of the buildings, bathrooms and garages. Good thing we brought our bikes - we learned that from going to many SCCA Solo Nationals, where you walk a mile going here and a mile going there, many times a day.
As we pulled up I was in a bit of a panic, as my NASA TT3 classing sheets were a mess and I needed a fresh blank copy to re-calculate and finish my classing, and we needed to download and print our dyno certification sheet that we had True Street fill out for us. Amy went to find a printer and I went to Tech to see what I needed to do. See I am still used to the SCCA way, where they insist on Teching the car at every single event, so I figured I needed to do the same here. Once at the Tech garage and scales I met Alan Blaine of Blaine Fabrication face to face for the first time (we've purchased his products and cage kits before), as he works tech at many NASA events on the west coast. He said the scales were open until 5 pm, so I sprinted back to the trailer 47 miles away to unload the car and try to get the front end and splitter installed by myself, while Amy was looking for that printer. I didn't ask him if I needed to tech the car... he assumed I knew, which I should have.
Left: My TT classing sheet was all jacked up when we arrived (but I fixed it). Right: These guys were doing it right - garage, air jacks, GT3
Got the car out of the trailer (without side mirrors and a dead battery - ever try to push a car out of a trailer with one hand, while sitting in the seat and steering backwards, blind, then bump starting the motor in reverse, coming down the 12 feet of ramps??) and started by myself, somehow. Left it running to charge the battery (it sat for 2 days in the trailer with something left on), then I crawled up to the forward part of the trailer and made a hole to get to the front bumper cover/splitter assembly. Once I dragged it back to the "cliff" of the front of the trailer, I tried... but it was just too heavy lift up over the generator, compressor and other junk on the floor that were in the way. There was nobody at my end of the paddock - it was a ghost town. I had the front end perched on my back like a donkey and tried to drag it out, but there was no way to get to the side door on my own without dropping it. Nothing replaces an extra set of hands. Time ticked away and some expletives may have snuck out. Right when I'm about to wrench my back doing some stupid contortions to get this massive splitter assembly out, Amy rolls up and we together we got the front end out of the trailer without scratching the fresh paint, and started the front end installation and alignment.
This should only take 15 minutes, but that's assuming everything goes smoothly. My side bolted together fine but Amy ran into problems from the beginning. She stripped not one but two bolts during the bolt-up assembly, and that blew our 5 pm "tech deadline". Once I finally got the front end bolted together properly I finally drove the car to tech at 5:20 pm, and it was all locked up. Crap! How did we plan this - to drive 25 hours across the country and miss Tech closing by 20 minutes??
Then I found out from Facebook NASA TT friends, who were more familiar with NASA Nationals, that we didn't need to go to Tech at all. Our NASA Annual tech + logbook was good enough. Tech was only there for people with new cars and/or no annual tech. Sweet! I cracked a beer and calmed down considerably, talked to a few friends we ran into at the far end of the paddock, then we both rode the 21 miles across the paddock and got to the 6 pm welcome dinner that NASA held in the Clubhouse. Decent meal, cash bar, lots of event specific chatter from the higher ups, and there were hundreds of people there. There was a moment of silence for the recently departed Roger Miller, who was part owner of the track and the NASA Utah region director. Tragic loss, with a family and 9 kids. The dinner broke up after the opening talks and we met with our race group leaders, where TT was told simply to "be at the 8:30 am meeting Thursday morning". Good enough for me.
As we left the dinner the rain started rolling in. WTF - I thought this was the desert?! We buttoned up the car as best we could (it wasn't going back into the trailer until we left on Sunday, because doing so would require the front end to come off - and we weren't about to start wrestling with it!) and put a big plastic trash bag under the hood ducting and over the motor, then headed to our hotel in nearby Toele, Utah. Amy and I stayed at a little Hampton Inn in Tooele, less than 10 minutes from the track, for the first 2 nights - which was a big mistake. See, the folks in Tooele know when there's a race at Miller and they jack the hotel rates WAY up. Also, this town has very few restaurants, with Applebee's being the number one rated place to eat. Great...
We got to the track early Thursday morning and I went and weighed the car, just to make sure our scales matched up with their scales. They warned me, "Every weight is official". Luckily our scales matched and the car came in plenty heavy at 3853 lbs, with nearly a full tank of 93 octane from back in good ole Texas. This track (and state) had only 91 octane for their premium pump gas, but luckily the track had racing fuel in 98 unleaded, 100 unleaded and 110 leaded. The rest of the week I would fill up with a 50-50% mix of 100 (at $9.22/gallon) + 91 (at $4.44/gal), using roughly 3-4 gallons per session. And we ran 9 sessions that week, so there were a lot of fuel top-offs.
continued below
Former site sponsor
Fair is offline
Old 09-19-2013, 10:43 AM   #213
Fair
continued from above
I went to the first TT meeting and Greg Greenbaum laid out the rules and procedures. Greg was stern but his rulings made sense, and he actually explained the reasoning behind every Supplemental TT Rule for the event. NASA is the exact opposite of other club's which "rule by committee", as one person sets the rules for TT/ST, and can make an adjustment quickly and decisively. They also use this thing called "logic", which was refreshing. We had great TT meetings all week. Anyway... We turned in our TT paperwork and dyno sheets, which they reviewed over the next 24 hours, and helped us fix on Friday's meeting - where the complexities of TT classing were finally explained to me coherently. Honestly, the ST rules wording explains the power-to-weight classing formulas better than the TT rules, with which it shares the same basic premise. This wording from Page 8 of the Super Touring rules explains it best:
Note: If one knows the competition weight of the vehicle, a simple reverse calculation will yield the maximum horsepower allowed for that vehicle. Begin by adding/subtracting all of the Modification Factors for the vehicle as listed above. Then use either the 5.50, 8.00, or 9.0 ratio (depending on which class the car is being prepared for), and subtract that number from the ratio to get the vehicle’s actual target wt/hp ratio. Divide the competition weight by this number to obtain the horsepower target.
I've had this argument with several folks, but now I know that the way we had been doing it (reverse calculate peak power from weight, using your modified power-to-weight number with all of the handicaps and bonuses added in) is right. I just wish they would state it the same way in the TT rules.
In our meetings we talked about not passing on the outlap AND not passing on the first hot lap without a point by, which was a new procedure to me (but apparently is in the TT rules). I talked to a few folks that were gridded higher but slower than me on the first lap, and eventually arranged point-bys and schemes so we could stay out of each other's way during our sessions. After I switched to A6s I was the one giving point-bys and getting the heck out of people's way on Laps 3 or 4, too.
During the week we ended up doing a good bit of set-up work and even a few small repairs to the car. Ryan and Brandon were set to fly in EARLY on Friday morning and Amy would go get them in SLC, and be back in time for the first TT1/2/3 session on Friday. Well, that didn't work out, as they missed their 6:40 am flight out of DFW airport. Here's a tip: don't EVER fly Frontier airlines. They close the boarding counter a full hour before the flight leaves, and the same personnel help load luggage and stuff onto the airplane. Less people, less service - that is the Frontier motto. They got there 1.5 hours early but were held up in security and then got stuck in the line at Frontier for a long time, as they only had one counter person and all of their self-serve check-in kiosk terminals were broken. Then, when they were 2 people back from getting to the lone counter lady, she says "That's all, folks - you will have to take the next flight!". Total BS, and this was the first and list time we will use this crappy airline. Anyway...
Since Amy and I were the only crew there for all day Thursday and Friday, we ended up doing some tire changes and tweaks on our own. And since some dingleberry forgot the key to the generator, we had no electrical or air power all week. And without a cordless impact (who needs it when you have a big air compressor and air tools?!) that meant doing tire changes with hand tools, with extremely long wheel studs. As prepared as we were, this small thing hung us up.
Left: The "keyless" generator made me less than happy. Right: Only thing I managed to break in 9 sessions on track was this bleeder
After my 1st Thursday session I noticed a brake bleeder that was leaking fluid, so I cleaned it off and kept an eye on it. We had calipers delivered Thursday morning by the folks at Maxcyspeed, who wanted to come watch the races for a couple of days, and swung by Vorshlag to grab everything we forgot on the way. Thanks again, Stuart and Doug! We're working with these guys on some new shock development work, too. By Friday morning I couldn't ignore the bleeder any more - the bleeder or the whole caliper needed to be replaced. Well, damned if I cold find the 1/8" punch needed to swap over the pads (forgot it), and I didn't want to fight the new helicoil repair on that caliper (same one!), so I just swapped in an extra bleeder we had in our extensive and well marked spares boxes. We also brought a spare splitter, driveshaft, radiator, hoses, belts, pads, rotors, calipers (eventually), fluids, wheels, tires, lug nuts, and a lot of nut and bolt hardware.
We started off the week knowing we had 4 days worth of sessions to get a good time in, and I figured that I would need some time to learn the track (I was still learning it on the 9th and final session Sunday). The first tires I planned for Day 1 and Day 2 were some well worn Hoosier R6 tires on the grey 18x12s; these were the same tires we used to learn the track at NOLA, Hallett, and two previous ECR days - they were pretty well shot, but had enough usable rubber that should have allowed me 2 days worth of sessions to learn this tricky track. We also thought the weather would be more consistent in the desert, but the opposite proved be to be the case.
Left: Grey wheels = R6. We ran these from Thursday thru Friday mid-day. Photo from Head-On photos. Right: White wheels = A6 tires (which we ran Friday afternoon-Sunday)
By Friday afternoon my times were not getting any better running on these R6s, and they were hammered, so we switched to the used A6 "scrubs" we had brought mounted to the white 18x12" set. These tires had also seen use at NOLA, two autocrosses, and another track day, but had what looked to be good rubber. Tedious tire changeover with a mistake made on the rear (forgot that this original set of 18x12" rears needed a spacer), but with some help from Jack Hidley of Maximum Motorsports we got the rear wheels fitted just in time for my last TT session on Friday. The car was a TOTAL MESS on these tires, and I put 2 wheels off of the exit of T1, after braking from 150+ mph. Loose, scary loose, and no faster.
Once Ryan and Brandon were there (Friday evening), Amy and I could focus the rest of the week more on talking to racers, customers and vendors, plus driving, and spent less time on the car prep. Ryan worked his butt off for 2 days and fixed the stripped bolts on the RF flare mounting plate, changed the car over to our only set of sticker A6 tires on Saturday morning, and noticed a swaybar setting I had forgotten about (it was set at full soft, and part of why the car was so loose). He also made some more wing changes, which we kept adjusting on nearly every session Saturday and Sunday, kept the car fueled, and kept me from forgetting something in our procedures (turn on transponder, check tire pressures, turn on AIM and vidcam, get belted in, turn off traction control, etc). I drive better when I know that I have good track support crew with us, too.
continued below
Former site sponsor
Fair is offline
Old 09-19-2013, 10:44 AM   #214
Fair
Brandon did his picture thing all week and got hundreds of amazing pictures, and even some external videos, of our car and many others. He was hustling around the track, going from corner to corner to get several views and angles. We also did a "garage crawl" on Saturday afternoon where he followed Ryan and me, oogling over race cars and pointing, "Shoot this!" and "Get a picture of that!". I felt like a kid in a candy store. We looked at a lot of trick aero ideas, too.
The weather we saw at Miller over those 5 days is hard to describe, other than tho say it was psychotic. It would be calm and beautiful one minute, with white puffy clouds and amazing blue skies... then some storm cell would roll in over the mountains and all hell would break loose. It rained on no less than 3 of the 5 days we were there, which shot my "Tire Strategy" plans full of holes. We saw some HOT sessions (96°F), some very WINDY sessions (40 mph wind gusts, which blew apart all manner of EZ-up tents and we ALMOST lost our roll out sunshade), then some sessions where it was 70° and calm, and some that were raining. Going to the airport Friday afternoon to pick up Ryan and Brandon we drove through a sand storm. Like, a bad one - I was "looking for the Worms on planet Dune" bad. We saw it all that week, I tell ya.
We met and talked to a lot of new folks that week. NASA's Todd Covini brought Mark Wilson and Bruce Smith from Ford Racing by our paddock to meet us and look at the car. Bruce immediately pointed out the issue we had with our oil separator lines (PCV valve - thanks, Bruce!) - nothing gets by these engineers. I tried to grill them for hints on the 2015 Mustang, but they played it cool "Wait, there's a new Mustang next year?". Haha, two funny guys. I also got to finally meet people face-to-face such as Lex Carson of Motion Control Suspension, Jack of Maximum Motorsports, Paul and Brian Faessler of Paul's Automotive Engineering (a father and son team who campaign the amazing AIX/STR1 Mustang below), and many others. Met a ton of racers and competitors in various classes, too.
Our lodging situation at this track was a learning experience, too. If you ever go to race at Miller, don't stay in Tooele. Like I said, the town has too few hotel rooms and they jack the rates up when racers come in. We eventually found one good place to eat (a new place called The Brewhouse, where we dined with the Maxcys), but other than that it was down to "Taco Time" or some other skeevy looking fast food joint. The track had an outdoor cafe (meh) but better food at the Clubhouse, which overlooked the track. We watched some races and ate lunch up there twice, and the food was pretty darned good for track fare.
Amy had booked us at 2 different hotels for the week, and I thought she was nuts - but it turns out I'm glad she did. Since the little hotel in Tooele was sold out of "double queen" rooms (for when Ryan and Brandon arrived) and the prices were insane anyway, she had booked our last 2 nights at an Embassy Suites in SLC, near the airport. It was a solid 25 miles away from the track (instead of 5), but it was well worth the drive. These nights cost HALF what the dumpy hotel in Tooele did, but the rooms there were immense (suites with a living room, bathroom, bedroom) and better appointed than my own home; they made omelets and other items to order at breakfast; and there was an open bar with hors d'oeuvres every day from 5-7 pm. Which we made use of both nights we stayed there - four rum and cokes will "calm the nerves" if you happen to be 5 seconds back from the leaders in your class. If we ever go back to Miller, we're booking at the Embassy again. Brandon did his foodie thing and found 2 great restaurants in SLC for us to eat dinner at, both nights they were in town: Red Ginger Bistro (Japanese) on Friday night and The Red Iguana (Mexican) on Saturday night. Mmm, MMM! Both of these places had long waits but for good reason - they were excellent. Who knew SLC had such a diverse selection of good food? And to have great Mexican food - in Utah!? This joint had 9 different mole sauces... Nine. Never would have believed it if I did not see it first hand.
Vorshlag Losing Employee #1
So as I wrap up this post I need to give a shout out to an employee who is leaving us. Back in 2008 we hired our very first employee, an E36 LS1 kit customer named Matt. He was a college student at the time and wanted to work for us part time answering phones and such. We put him to work and he eventually became phone support, an order builder, our IT guru, then our Operations Manager, Meanwhile he graduated college and stuck with us for several more years after that.
After 5 years of service, Matt is leaving the Vorshlag family at the end of this week. He has a great opportunity at a new start-up company and we wish him well, but he will be sorely missed. Matt had 4 different cars we used for here for Vorshlag, AST and MCS product development over the years, including a Golf GTI SMG, a 350Z, a 95 M3 LS1 and a '13 BRZ. He will still be a tester for us on those last two cars, too. Adios, amigo!
Matt wore a lot of hats during his stint as Ops Manager here and we're splitting his old position into two new jobs. The Vorshlag Jobs page on our website had those two openings listed, but we already filled one of them (who starts tomorrow). If hard work in the automotive aftermarket, constant deadlines and low pay seem appealing to you, go to that link and apply.
Until Next Time
Yep, I'm running a bit long in my post again, so let's call it a day (well, each of these posts takes me about 2 days to write). As usual, a lot of these things I wrote are our observations and shouldn't be taken gospel. Like the notes on places to stay and eat in Tooele - we have only been there once, and could be missing a gold mine of options hidden behind the mountain of crappy fast food joints. If you have better suggestions for us about anything, feel free to chime in. But for the car/prep/aero stuff... we're still working out some kinks and know that the splitter was too long, the flares look a little goofy, the car is too heavy, and that it is silly to bring a street car to a National championship race. We will learn these lessons eventually. Its still a work in progress, too.
My next post will finally cover the racing action we saw on the 4 days of competition at the 2013 NASA Nationals, during which Time Trial ran 9 timed sessions. Only one fast lap is needed to win, and we had a lot of chances to get that - and many of us put in our best laps on that last session! I will also talk about a few race groups we watched, such as GTS, AI/CMC, and some others. Then I will cover what we have in store next for our TT3 car, for future S197 development, and the new car(s) we are moving to for the 2014 season. What?! No more red 2011 GT? Well, it depends on a few factors and is currently a solid "maybe"... but I think you folks will like the potential replacement.
More soon,
Former site sponsor
Fair is offline
Old 09-20-2013, 08:51 PM   #215
brembo12
Thumbs up
impressive stuff guys.......the best of luck to your team! good luck Matt.....a valued hired hand for sure
2012 Performance White BBP/MT82 GT 400A Lava Red/Charcoal more as it unfolds....
brembo12 is offline
Old 09-21-2013, 11:06 AM   #216
saunupe1911
saunupe1911's Avatar
Great thread and posts
saunupe1911 is offline
Old 09-30-2013, 04:09 PM   #217
Fair
Project Update for Sept 23, 2013: When I started to finally write this last piece of the Miller event coverage, on Monday Sept 23rd, we had just gotten back from yet another NASA event (TWS), so I was already 2 weeks behind. And it took me a week to get all of this written down, after looking at results sheets and watching the in-car videos from 9 sessions I drove over the 4 days. In this installment I will talk about our actual racing experience that week at NASA Nationals... finally! I will start with how they do things at NASA's "big show" event, which differed ever so slightly from the dozens of regional NASA events I've done in Texas, Louisiana, Oklahoma and California over the past six years. For the most part it was a bit more serious, but no less fun.
Impound Is Important
I'm going to talk about Nationals impound, as it had a bearing on my final finish placing. The way NASA runs their all of their road racing and Time Trial classes is pretty unique compared to other clubs, but I really like The NASA Way and I have said so many times. Sure, there are some quirks, but I learned a lot at this event and understand the various classes better than before.
One of the biggest differences in NASA is their proclivity to measure not just chassis weights but to also measure horsepower output in most cars & classes, with an actual chassis dyno. I have written letters to other clubs asking them to MEASURE HORSEPOWER instead of relying on some quaint "gentleman's agreement not to cheat" nonsense, and not rely on poorly written rules or very outdated displacement-to-weight formulas - that have been proven to be ineffective for 40+ years. Still, even with continuous dyno testing and weight checks, NASA is always investigating new ways to keep racers honest. Now they are even looking at GPS based data loggers going onto race cars - looking for spikes in acceleration past what the car can physically do at a given power and weight. They were testing a new black box data logger on a few cars which we've started to see in Professional Racing circles. Look for this to go into some of their race groups in the next season or two, hopefully. I totally support this type of active policing in racing... 'cause racers naturally will try to push the boundaries. This isn't the NSA or Big Brother, this is "let's keep everyone honest" type of thing. Good stuff.
Anyway, NASA's current techniques to police classing include 2 main components: weight checks on scales (virtually ALL classes) after qualifying and race sessions, and measuring horsepower on a chassis dyno for most classes. So many classes within NASA have some "power-to-weight" component that checking the cars on a dyno is common practice, and at Miller they didn't hold back. They must have checked hundreds of cars on the dyno that week. Qualifying races, random TT sessions, and the top 3 in almost every racing class got checked at least once. There were 3 dynos on site that week getting a steady stream of business (it was a constant background noise), but one "official" dyno was used for all NASA Impound checks (a trailer mounted DynoJet). The others were being used for tuning and verification before the final Championship races began. Most of the W2W classes had a big final race on Saturday or Sunday that determined the Champions, whereas raced over 4 days to get our one best lap (which was unique).
It seems like common sense to me; if you want to keep cars competitive and legal, you weigh them and dyno them often. NASA officials even had racers at this event put evidence tape on OBD and other computer ports or "any aftermarket switches within reach of the driver" to show that they haven't been tampering with power levels or tunes while on track, too. And for TT this is extra important, because we raced over FOUR DAYS and 9 sessions that counted (+ one Warm Up practice session on Thursday morning, used just for gridding purposes). We could make changes to chassis and aero set-up all week, but if we wanted to make computer/tuning changes we had to go to Tech and the TT Director to ask permission, first. I brought an SCT tuner with the ability to alter timing and RPM on our car but I never messed with it.
On the first day, I heard that 3 or 4 American Iron cars were popped for blowing dyno tests, and a few people were whining. But they warned us, every race group, that they would be dyno testing a lot of cars, and they did. And I'm GLAD they did. I wish this happened at more Regional TT events, too (I have seen race groups have the top 3 finishers dyno'd at a few NASA Texas Region events, just not ever in TT). Sure, dyno testing is a logistical hassle, especially for AWD cars, but it is a necessary tool to help keep everyone on a level playing field. The future black box real time monitoring could be even easier, when the technology gets good enough (and cheap enough).
BMW E46 M3s are becoming increasingly popular in TT3/ST3/GTS3 classes
So this isn't the official racing procedure verbatim, but what I observed on how this worked in the Time Trial group. First, we had to be on grid in your assigned spot before the first car went out on track. Late to grid? Too bad, you lost that session. Why? They didn't want people popping out of the hot pits into the fastest part of the track and messing up other people's laps. NASA Texas has started to do this, too, and it is a welcomed change. Next, if you came off track before the end of the session, you went to Impound. Period. No tweaking the car on the hot pits, no going back out to finish the session, nope. Same reasons as above - coming back out on track during a hot session was dangerous and interrupted the flow of the racers, who are gridded in the order of their lap times (fastest to slowest). Also, they split the large TT contingent into two race groups that never shared the track at the same time: The "Letter Classes" (TTB-TTE) ran in Race Group C and The "Numbered Classes" (TTU/1/2/3) ran in Race Group H. It was nice for the faster TT guys to not have to worry about catching the E cars on lap 2, which can happen when all of the TT classes run at once.
Once TT racers came off track we were held in Impound until a TT Director released us, usually not until the session was over and everyone was in. We couldn't jack with the cars in Impound AT ALL. The driver could stay in his car and have ONE helper CHECK tire pressures and tire temps -or- he could exit the vehicle and do it himself. That was it. No dropping tire pressures, fiddling under the hood, or any funny business. And if you wanted to check tire pressures you had to ask a NASA official first, and they observed. Why? We were told because some folks have gamed the system in the past and dumped tire pressures in Impound down to 10 psi or less, then if they were dyno'd... yep, the numbers would be much lower than normal. So if you were caught dropping tire pressures in Impound then they gave you a dyno chit, aired your drive tires up to 40 psi, and off to the dyno you go. Automatic dyno check. Another sensible measure and fewer chances for shenanigans.
"A dozen ways to skin a cat" - here are two very different approaches to a TT2/ST2 build
Over the week my car was weighed 5 times, which was about average, but never was quick enough to warrant a dyno check. I was sweating it all week, as was everyone. Many of the faster TT guys' cars saw the dyno 1, 2 or even 3 times that week. How they dyno'd TT cars was simple. First, a TT director called down to Impound with a list of cars to by dyno'd and/or weighed ("If you drop a lot of time and move up to the front of the pack, prepare to be dyno'd"). If you were called out to be Dyno'd you got a "chit". Every car getting dyno'd was weighed first, which was recorded, and if it was not greater than your stated weight you got a session DQ. Same for anyone just getting a weight check. The closest to minimum I got was 21 pounds (3791 lbs with driver on a 3770 lb stated minimum) but I was often 50-60 pounds over, depending on fuel load. I saw some competitors get within 1-2 pounds, and several go under. We all were issued a decal that had to be posted on the side of the car with our declared minimum weight, max torque and max hp numbers, as shown below. Many of us made changes to this after we talked with TT officials, too.
continued below
Fair is offline
Old 09-30-2013, 04:09 PM   #218
Fair
Left: After conferring with TT officials, instead of assuming my car would dyno low at altitude, I revised it to the latest tested number
So if you got a dyno chit, you went straight from the scales to the dyno, 50 feet away. Nobody could touch the car but the driver, and you couldn't open the hood or do anything else. Once it was your turn the dyno operators took the car from you, used an elaborate series of ramps to get it up onto their mobile Dynojet trailer, strapped it to the rollers, and got some fans going on the radiator and opened the hood. Once the engine was up to speed in the 1:1 transmission gear they asked about redline RPMs or rev limiters, then did three back-to-back dyno pulls. Vrooom.... vroom.... vroom. Didn't take 60 seconds. Then if your car made more than your claimed dyno number ("popped dyno" or "blew dyno"), even by 1 a hp, you got a session DQ. Then the NASA TT directors would calculate your latest dyno and weight number, and if that ratio was over your class minimum, ALL of your previous sessions times back to your last successful dyno/weight check were thrown out. This matters for later, so keep this in mind.
Now that I know how this works I would have ASKED for a dyno earlier in the week. Because a successful dyno/weight check means your times up to that point are SAFE. Just like when we come in from a TT session early, to "bank" our times. Why? Because if you have a 4-off or a spin during a TT session, you lose ALL of your times in that session (session DQ). It has happened to me twice in the past 6 years (spin or off during TT), and it sucks. So when you know you have a good lap time in the books (from watching your onboard lap timer), most of us come the hell in! Again, this matters for later.
They had similar procedures for virtually every NASA race group, but I'm sure there were small differences I don't know about. In any Championship W2W race, for instance, if a driver blew minimum weight or blew the dyno, they were DQ'd and everyone moves up a space in the standings. So everyone was watching the dyno all week. And yes, even at 4500 feet of elevation, they use an SAE correction factor to correct for that. And it was huge, close to a 20% correction! I'm used to seeing 0-2% corrections here in Texas, sometimes even negative 1-2% for SAE. So you couldn't just rely on "the elevation will soften my numbers", no sir. You have to factor that in. I was a FOOL for not getting a dyno check before the event started and for not ASKING for a dyno during the event. I got lucky, I guess, but if you were in the top 3 during the week you saw the dyno, trust me. I wasn't in the top three until.... well, the very end. I'll get to that.
Race Coverage - Day By Day
I don't know if I mentioned this earlier but the course being run for the week of Nationals for ALL race groups was the 3.0 mile "Outer Loop" CCW, and there were no HPDE groups running at Nationals. This 3 mile course is the fastest configuration of the 4 possible track layouts at Miller, and has many high speed turns and a LONG 3500' front straight. There is some elevation change in a couple of corners, but for the most part it was like most other desert tracks I've run: flat and with few visual markers. This meant many corners looked identical, which confused me a bit. I have never run this track before and struggled all week, learning the layout. And we fought all week to find balance with the set-up...
Like we do for every NASA TT event, we made our own maps in case they didn't hand any out. They had great maps, though
I will break up my "race coverage" into the 4 days we had to get our best lap time. Every session from all 4 days of Nationals counted for TT, and you only had to bag one fast lap in one of the 9 official sessions (the Warm-up session was the first of 10, really, but it didn't count towards times). Some days we had 3 sessions and some days we had 2, which I will explain below.
Results: http://timingscoring.drivenasa.com/N...Championships/ (TT3 was in Group H)
I missed one session due to rain and another where we had to work on the car, but ran every other one and thankfully had no DSQs (a spin or 4 off will net you a DSQ). I had some close calls, and came in early to "bank" a good lap time when I noted a decent time on my AIM Solo display (which was extremely accurate all week, matching the official transponder times usually to the hundredth place).
Day 1 - Thursday
TT had our first mandatory meeting of the week at 8:30 am this day (one of 9 meetings we had that week), where we went over the basics, then TT1/2/3/U (Group H) had our first "Warm Up" session at 10:30 am (TTB-TTF ran in a separate run group all week - Group C). I went out in this session on those well worn R6 tires we brought on the grey wheels and fumbled my way around the track. Car was LOOSE at speed! Aero balance felt terrible, and any corners over 80 mph the car wanted to be sideways. The slow speed corners felt fine, but it was a complete handful everywhere else. I thought we had this sorted at our ECR test, but that track's fastest corners are probably sub-65 mph. Some of the corners here at Miller I was entering at 100-150+ mph. Scary fast, and I was working on my lines and my "testicular fortitude" in every session. I stayed out in the Warm Up for the entire time and had a best lap of 2:10.804 on Lap 5, and a 2:10.9 on the lap before, neither of which was fast. The quickest TT3 car in this session was a red E36 325is, which had an S54 3.2L M3 engine swap and good aero, driven by an old autocross buddy Chris Mayfield. He ran a 2:06.448, so he was fast right out of the gate. Ken Smith in the yellow ST3/TT3 C5 Z06 ran a 2:09.306 in that session (and was broken down on the side of the front straight, then came on the hook), with two faster TT3 cars between him and Mayfield. The Miller track crew did an excellent job and was doing "hot tows" all week (towing cars in with rolling local yellows, while keeping the racers going). I was only 5th fastest out of the 11 cars running in the TT3 class (at this point - we saw 12 different TT3 cars by week's end), and well over 5 seconds back... yikes. TT3 was the largest TT class of the event, by a good margin over any other (here's group C).
Print-outs showing results from Day 1's 3 TT sessions: The TT Warm up, TT Session 1 and TT session 2
In that Thursday Warm-Up session I ran so many consecutive hot laps that I saw some warmer than anticipated engine temps on lap 6, even with the lowest ambient temps of the day (high 70s). On Lap 6 the temp gauge shot up to maybe 3/4 of the range from "C" to "H", which is warmer than we ever see in this car. It was not that warm outside yet, so I chalked it up to the thin air here at 4500 feet of altitude and maybe still having an air bubble passing through the newly set-up cooling system (I added some distilled water in the pits after this). Talking to other drivers they were seeing the occasional warm temp readings, too, and I was told by many "high altitude racers" to be on the watch for this at Miller. I took a cool down lap and stayed well out of people's way while coming in, and with a 3 mile course the cool down laps can take a while. Within 30 seconds the engine temps came back to the "middle" of the range. This happened two more times during the week, saw a warm temp after too many hot laps that was corrected in the first cool down lap..
Navigating the "Attitudes", 3 S-curves right in a row with some wide, tall and nasty curbing
continued below
Fair is offline
Old 09-30-2013, 04:10 PM   #219
Fair
So, as with all NASA TT events, the times from this first "Warm Up" session on the first day only count towards our grid positions for the first "official" TT session, session 1. We checked air pressures hot and they were WAY higher than I thought they'd get up to, so we bled off 8-10 psi from each tire, from hot. We had an 11:10 am TT meeting where we did roll calls and listened to Greg give us the latest session DQs for spins, offs, weights or dyno (which were not printed on the individual session time sheets, strangely enough). Someone in the group also asked "what is a 4 off here", as there are some rather WIDE curbs at Miller - in some places more than 25 feet of paved but painted curbing. The biggest section of track in question was the "Attitudes", Turns 8/9/10, which are S-curves in rapid succession that also fall down a hill. Apparently this section was a bit controversial, and some race groups were seeing a handful of drivers really pounding over the curbs, some catching 4 wheels in the air and short cutting Turn 9 altogether (just going straight over the curbs/gravel and leaving the track). After some discussion it was ruled that the white painted line was to be considered the edge of the track and as long as 2 wheels were still "touching the paint", that was allowed. Tons of latitude but no more "cutting a corner". If we were 4 wheels over the paint it would be a "4 off" and a session DQ.
Above photos by Brian Smyer
I was staying off the curbing in almost all corners, as the bumps were making the already very loose car even more twitchy. Like the picture above, where my car is already sideways after just touching two outside wheels on the paint, is what would happen. So I stayed off the curbs on almost every lap. I tried to take a bit more on the last day, with some negative consequences (video of that in a lower section). Other drivers were a lot more liberal with their curbing, though. And it likely helped their times - I just couldn't see jumping them like that and doing the "4 wheels in the air" thing. I would have ripped the splitter off and done all sorts of damage to our car. In the AI circles I heard one driver admit that cutting Turn 9 was worth a full second on his lap times, and there were a few of those guys really getting a lot of time using the curbs. Amy was there and if I would have broken the car on the curbing she would have KILLED me!
Just watched my TT session 1 video, which began on Thursday at 2 pm, and it was 20 degrees hotter than the TT Warm Up. At least this time we were gridded better, but I still had to deal with several passes, and the car was SUPER loose in the first 2 laps. I was finally figuring out where to shift, what gear to be in for each corner, pushing some still-early braking points, and just beginning to get a feel for where I was and where the apexes should be. I took a good number of laps in this session and dropped down to a 2:09.039, with my fastest lap on Lap 1. I spent the rest of the session trying different lines, braking points, etc. In Session 1 Ken Smith really picked up the pace and moved into the lead with a 2:05.099, with Mayfield right on his tail at a 2:05.753 time. Steve Nagel found a lot of time and dropped to a 2:07.284 and 3rd place in his white E36 M3 with aero and a claimed 310 whp, nearly 2 seconds quicker than my times.
The third and final TT session for Thrusday was TT session 2, we started at about 5:30 pm (about 30 minutes behind schedule) and ambient temps were up to 94 °F when we started. It was so delayed and so hot that attendance was pretty sparse by the time we finally got released from grid. After 2 false starts for this session we finally heard the reason for problem - Mark Baer had a pretty bad crash in his GTS BMW going into The Tooele Turn, T11, and they had to air flight him to the hospital for observation, tow the car in, and do some quick repairs to the armco.
Smith (left) and Mayfield (right) traded the TT3 lead all week, but nobody else could seem to catch them
As I recalled after watching my video of this session, I was still pretty lost on 2nd half of the track after Turn 7, where I was confusing Turn 11 with Turn 13, and I still couldn't get the entry speeds up into Turn 7 (Witchcraft) or my line right into Turns 8/9/10. Really struggling to grasp this track layout, and there was a lot of gravel on the track from people going off and on at various corners. In my video I noted that the car was using about 5 gallons per session, and I was seeing "155 mph" on the speedo (probably more like 150mph) as I was braking into Turn 1. The car was still a loose mess at speed, and Amy and I were running out of things to change (tire pressures, wing angle, and some other things). I nearly looped the car going into Turn 3 on my 2nd hot lap, so took a cool-down lap and then another hot lap on the now well worn R6s. Just touching one of these monster curbs was setting the car into bump-steer convulsions. My best lap was again my 1st lap out, and nearly matched my previous session at a 2:09.054. Mayfield slowed down to a 2:05.574 and Ken Smith was in the 2:05.927 range, with Nagel slowing down to a 2:10.5. The higher ambient temps were hurting everyone and I was 4.5 seconds back from the class leader, not making up any ground.
My outlook was pretty bleak that night, but we had our lone good meal in Tooele (The Brewhouse) with Doug and Stuart Maxcy of Maxcyspeed. I drank away my sorrows and dreamed all night about turns like Witchcraft and the Attitudes, that were straight up kicking my ass.
Day 2 - Friday
After some dismal driving on Thursday I had planned on doing some work early Friday morning to the car and going out on the R6s again in the first session with some set-up improvements. Then Ryan and Brandon missed their very early flight, so it was just me and Amy again, and with too much to fix we skipped the first TT session of the day. During that time we replaced a leaking caliper bleed screw, dialed in 2 degrees more angle of attack on the rear wing, re-tightened the splitter mounting screws (several had loosened up), reset air pressures, and went out in session 2. Turns out we neglected to add enough fuel, so I was worried about fuel starvation. The left side tires were more abused than the right, which surprised me as there are more left hand turns than rights... but a lot of the high speed turns are right handers, and those tore up the appropriate side.
Left: Grey wheels = old R6s. Right: The fastest AI car was a World Challenge Boss 302R, which ran a 2:07.860 in the final race
At this point we had been weighed twice. 3791 lbs was the lightest and as high as 3836 lbs with a lot of fuel. Brakes looked good - the Carbotechs were wearing very well for the abuse I was throwing at them. I have never braked this car this hard, from these speeds, this many times in a row. Some say our upgraded GT500 14" rear brakes "are worthless" compared to the stock 11.5" rear discs, but I disagree strongly. This car was the heaviest in the TT3 class, had one of the highest terminal speeds into Turn 1, yet I could brake as late or later than anyone else. In some cases I was braking nearly 100 feet later than some TT2 and TT3 cars. The brakes just flat worked, flawlessly, all week.
Just watched my TT session 4 video and I was pushing hard yet only managed another 1/2 second gain, down to a best of 2:08.537. Heavy cross winds made for major buffeting in the car on the higher speed sections, and the high ambient heat (2 pm, high 90s again) baked the track, overheated tires, and made for generally slower lap times. Only five TT3 cars went out this time, with Mayfield and Smith skipping the session entirely. Nagel went out in the white E36 and put in a best of 2:08.324, which was over a second slower than his best time from the first official TT session on Thursday. I was within 2 tenths of Nagel, everyone was slower, but I had found another half second, so that was at least a little encouraging. The R6s felt really awful and the car was still very loose at speed, and once the tires got hot after my 1st lap it was loose everywhere. I pounded out 5 laps (3 hot laps + 2 cool downs), well after almost everyone else had come in, and saw another 2:08.8 lap in the closing lap, but my first lap was again my fastest.
continued below
Fair is offline
Old 09-30-2013, 04:11 PM   #220
Fair
TT session 3, Session 4 and session 5 time sheets from Friday
For the Friday's final TT session (TT session 5) we we removed the Grey Forgestar 18x12's with the well worn R6s and slapped on the white Forgestar set with the the used set of Hoosier A6 tires. Clouds were rolling in, temperatures were dropping, and at the beginning of this late afternoon session it was down to 88°F. Amy and I had to swap wheels without any power tools, so it took a while and we barely made it to grid in time. Then we had another long delay on grid, as had been the case several times previously.
During this grid delay Brian Smyer shot the pictures above, as well as several others that he put into his blog post. "I fell in love with this mustang from Vorshlag so thought I would share a few images from Miller Motorsports Park" Brian also got some great images out on track, which I have scattered through this post (anything without the Vorshlag watermark was taken by him). Good stuff. After he took the above two pics the clouds rolled in and it started to look like rain again. Winds picked up, and many of the cars went out on sticker tires in this session, thinking it might be one of our last dry times for a bit (storms were predicted to roll in hard for Friday night/Saturday).
I left a gap to the rest of the field on the out lap, because I had been catching several cars gridded higher than me on the 1st and 2nd laps out, time and again. This session looked like the best conditions we had seen all week, and I had what I thought would be faster tires and some clear track ahead. I got a good run out of the last turn and pushed the revs in 5th gear down the front straight. With the higher AoA on the wing I only saw an indicated 150 mph into the braking zone (down from 155), but it seemed to stop fine. As I'm rolling into the throttle exiting Turn 1... the rear tires washed out, lots of counter steer, no help. I put 2 wheels off on the exit of T1 at 100+ mph and blew the lap. Took a cool down lap and tried to set up to try again.
After my 2 off I had let about 6 cars that were behind me go by, after I had gathered it up. So my next hot laps involved getting held up by virtually all of these cars as I re-passed them. The tires quickly felt greasy and the car was oversteering more than it had all week. My 2nd lap was only a 2:09.031, on the A6 tires. I knew I was in trouble and took another cool down lap, where I let a few of the same cars back around me, trying not to impede their laps. Started another hot lap, it was looking better on predictive timing, then exiting Turn 6 and I got blocked by two of the SAME cars that I had pointed by on my cool down, including one of the same cars that had blocked me on my previous hot lap. Very frustrating, my session was blown, the A6 tires were now overheated, so I threw in the towel and came into the pits. In that session Mayfield was 1.5 seconds quicker than his previous best, down to a blistering 2:04.170. Nagel ran a 2:07.808 as well, so it was a good session to get a fast lap in. My 2 off and subsequent blocked laps blew the session for me, but the tires never felt very good anyways.
After this session we buttoned up the trailer, left the Mustang out in the rain, and headed to the airport through a sandstorm to pick up Ryan and Brandon, who finally made it to SLC by about 4:30 pm. This was the night we switched hotels and the better accommodations, free drinks at the bar, and a good meal in SLC raised our spirits.
Day 3 - Saturday
We arrived at the track at 7 am and got to work on the car. We had a new game plan - don't wait until Sunday to put the sticker tires on, as the weather was too unpredictable and any of the next 4 sessions might be our last chance at a dry track. So Ryan and Brandon had the scrub A6 tires dismounted and the lone set of brand new "sticker" 315/30/18 A6 tires went on ($130 mounting charge from the Hoosier guys, ouch). Ryan tweaked the front swaybar, dialed some wing back DOWN, and I went out on track. It was 71 degrees, still very windy, but sunny and dry. Track was green from rains the night before, but I went out and pushed it hard anyway.
I was gridded behind Nagel and gapped him hugely on the out lap, so I wouldn't catch him on the first lap. Since he was running Yokohama slicks that took several laps to heat up he was a good bit slower for the first 3-4 laps in every session, and I still caught him by Turn 6 on the first hot lap. Got a little held up into T6 but took the pass on the exit. What freaked me out was his brake lights didn't work almost the entire week (they were operational by Sunday), so I had to gauge at when he got on the brakes, which was a bit earlier than me into T5 and T6. After I got around him it put me on a bad trajectory into T7 (Whitchcraft) and I got a little bit of curb into T8, and again into T11, which really caused the car to bumpsteer hard. I knew the pass and both subsequent curb touches had cost me some time, but I still managed a 2:06.6 on my first hot lap with the new A6 tires. Dropped two full seconds on my first lap on stickers, with tons of mistakes and delays... man, I was regretting only bringing that one set of new tires! The previous 2 days felt like a big waste of time, now.
Time Trial Results for TT session 6 and 7 on Saturday
On my second hot lap in this session I was on a flyer when my foot slipped off the brake pedal downshifitng and braking into T6, and I almost had an off. I managed to gather it up, with the left front tire getting way out onto the outside curbing mid-corner, and of course that lap was blown. At that point I wanted to "bank" the first 2:06 lap and started a cool down to then come into the pits... but I changed my mind at the last second and went ahead and took a 3rd hot lap. I had already turned off the video so I don't have details but apparently I got fairly clean track and managed to drop 3 more tenths and put in a 2:06.356. Considering that these were A6 tires, with which I almost always put in my best laps on the 1st lap and they fall off a cliff after that, I knew the car had more in it. After that 2nd 2:06 lap I came in to bank it. This new time briefly pushed me into 3rd place in TT3, ahead of Nagel. Most everyone was faster in that session and Nagel dropped a good bit of time on his 5th lap, and jumped back ahead of me back into 3rd with a 2:05.562. Mayfield dropped another 9 tenths to a 2:03.170 and finally jumped ahead of Ken Smith (who had a 2:03.3 from TT session 3) for the TT3 lead. In this session Smith had put in a 2:04.110, with the rest of the class was 2 seconds behind me in 4th position. The two tight battles in TT3 were between Mayfield and Smith for 1st in the 2:03s and Nagel and me for 3rd in the 2:05-2:06 range.
continued below
Fair is offline
Old 09-30-2013, 04:12 PM   #221
Fair
That picture above is from the grid before Saturday's final TT run group, session 7, which began at 3:45 pm. As you can see the bad weather really rolled in and the rain was eminent, and we even felt a sprinkle or two in grid. I had no windshield wipers (pulled them for less drag!) so I applied two coats of RainX to the windshield prior to going out. I was hoping to drop another 2 seconds, to maybe "get in the hunt", but that was a bit optimistic. I had watched some previous in-car videos and noted several of my driving mistakes, so I tried to clean up my lines, and again - my first lap was going to be the most crucial.
I dropped back a bit on the out lap and tried to gap Nagel, but I caught and passed him again in the braking to Turn 1 on the first hot lap, which threw my line off for this high speed corner, and my entries into T2 and T3 were slower. Rest of the lap was relatively clear and was a 2:06.6, with a pass and several compromised corners. I went ahead and took a 2nd hot lap, where I caught and passed a TT1 Corvette on the main front straight, then got held up a little by a TT2 Subaru early braking into T1 (so many cars brake early there). He pulled ahead in Turns 2-4 but I caught him a bit in the heavy braking into Turn 6. For the rest of this lap he stayed ahead and pulled away on the main straight. Hot lap 2 was a 2:06.111. I had a little more gap to the TT2 Subie so I took a 3rd hot lap in the row.
Braked a little late into T1 (155 mph) and got a little sloppy, then borked the high speed Turn 4 a bit, too. Felt like the rear tires were getting greasy, and they were. I watched the predictive timing off and on through the lap, and and it was only showing a 2:06.3-2:06.4 towards the latter 1/4 of the lap. The rear tires were really overheating by Turn 12, car was getting too loose, so I bailed on this hot lap right before Pit In and came into Impound. The 2 tenths improvement was at least something but I was still a 1/2 second behind Nagel's previous 2:05.5 (he ran a 2:11.3 in this session).
I guess because of the weird weather, higher winds and darker visibility only 2 cars dropped time in our class - I ran a couple of tenths quicker at a 2:06.111 on my 2nd lap and Bezard dropped from the 2:08s down to a to a 2:07.5 in his E46 M3 to close up behind me in 5th place. Smith was slower at a 2:03.9 and Mayfield was a second slower at a 2:04.1. So on only my 2nd session on "sticker A6" tires I was still dropping time, but I still felt there was more left to drop still.
Click above and skip to 5:57, where they spend a minute on our Mustang
One difference from this year's NASA Nationals was the "SpeedcastTV" coverage. There were cameras up on man lifts at a number of corners around the track and they were showing video live online at www.speedcasttv.com/nasa. There were also two announcers giving color commentary on the live video feed. They had a director who would tell the cameramen to switch from car to car and they'd stay with them for 30 seconds or up to a minute. The linked video above shows some footage from TT session 7, and at the 5:57 mark they cover me driving the red Mustang. One of the announcers was even a follower of this very forum thread and a fan of the car (thanks!). They talked about the car for a minute, which was cool.
Saturday night was a lot more upbeat, as I was at least within a 3 seconds of the 2 drivers who were trading the class lead (closest I had been all week) and I was only 1/2 second out of a podium position. We had 2 more sessions to go on Sunday and anything was possible. But it started to rain as the sun fell and it rained pretty much all night. We knew this meant another green track (no rubber down) for Sunday, so it might all be over for fast laps in TT. We had no more tuning tricks left up our sleeves so it was all down to the track/weather conditions and my driving on Sunday. Great...
Day 4 - Sunday
It rained all Saturday night so we were treated to a wet first session on Sunday, with drops still coming down. Only 7 drivers from the entire H group of Time Trial racers took to the track, but they got some extra SpeedcastTV time, so kudos to them. I skipped that session, as I didn't bring any rains and didn't see a point, with 8 other dry session's worth of times to fall back on. Don't need to stuff the car off track, either. So we waited for the 9th and final TT session, which began at 2:45 pm, and it was the last race group to run the entire week of the 2013 NASA Nationals. The track was green but dry, temperatures were down to 79° after the rains had blown through, there was a good wind again (which dried off the track quickly), and it looked pretty much like the best conditions of the week.
In the last TT meeting before this session we were told by the TT Director, "If you go faster in this last session, be prepared to be dyno'd". The top 2 in TT3 had already been dyno tested more than once this week, but almost nobody else in our class had, including me. We had all been weighed many times, and as far as I know there were no under-weights. We were told if we weighed under, or dyno'd higher than our claimed numbers, we'd get a session DQ. They would then take our weight and divide by the power test number, and if our ratio was under what the class allowed, ALL times prior to that would be thrown out, back to our last legal dyno/weight check from this event.
Final two Time Trial sessions were run on Sunday. Session 8 (at left) was raining but Session 9 (right) was dry and fast...
I went out on the same fresh-ish Hoosier A6 tires that we installed on Saturday morning (I saw more new sticker sets in this last Sunday session than in most others), with several heat cycles now acquired on them. I was sitting in 4th place out of 12 in class, 6 tenths behind Nagel in 3rd, with the two of us gridded side by side. We talked before going out and agreed to a point-by on lap 1 if I was closing down on him, like we had been doing most of the week, since he doesn't get tire heat until lap 4 or 5. He knew I was close to his times and was pushing to pick up some time cushion, too. He had a sizable crew with him including spotters with 2-way radios to communicate his and my times during the session. I really wished we had radios at this point, because I would have no way of knowing if he went faster. Amy and Ryan told me to STAY OUT THE ENTIRE SESSION, to make sure I got the most out of the car, but I knew my best lap would likely be my first. We fueled up heavy to give a bit more range and out I went.
Last TT SpeedcastTV video: http://www.speedcasttv.com/nasa/#/races/358
If you watch the above video it gives you some good action in TTU and TT3 during this session. The Godzilla GTR in TTU dropped 2 seconds in this final session and leaped into the lead by nearly 2 seconds over the Subaru powered Radical. That car's 1:55 lap times for a full bodied car were amazing. In the 9th TT session Nagel had dropped another tenth down to a 2:05.454, but spun it on course and on camera, late in the session - at approximately 21:20 on this 2nd linked Speedcast video, you can see him sitting crossed up and stopped on track. So that spin caused a session DQ and his new 0.1 second faster time was thrown out. So we have to look back at his previous best of a 2:05.562 from TT session 6 on Saturday. That was the mark I was looking for... mid 2:05s. So when I ran the lap below, I didn't know if I had beat him or not.
continued below
Fair is offline
Old 09-30-2013, 04:12 PM   #222
Fair
In-car video from the final TT group, Session 9, where I ran my best lap of the week!
My best lap was my first hot lap, once again, with a 2:05.579 - or 17 thousandths of a second back from Nagel! I stayed out and ran 3 hot laps in a row, which you can see bits and pieces of in the Speedcast video or in my in-car video, above. Nagel gave me the point right before the start-finish and I got a mostly clear track ahead of me for my first lap. I caught the TT2 Subaru again in Turn 4, T5 and was maybe held up a tick braking into T6, but he started pulling away from me after Turn 7. Watching my lap I was talking to myself and yelling at the car the whole time, might have left a few tenths out there, but I was on the ragged edge and tracking out to the curbing on most corners. When my lap timer said 2:05.59 after my first hot lap it was too close to call. So I went out in lap 2 looking for a tenth. I keep saying that on the video, "I just need a tenth... I just need a tenth!"
Exiting Witchcraft I pushed it a bit too hard and took the S-curves (attitudes) with a bit more curb than the car could handle and got it very crossed up. Kept it on track, barely, then cooled down for a couple of corners and went straight into hot lap 3. Tires were getting greasy and loose at the high speed corners in T2/T3/T4. Predictive timing was only showing low 2:06s and I was getting very, very frustrated. I needed to push it hard to find that tenth but could not afford to have an off. After 3 hot laps, where I noticed lap times slowing on each successive attempt, I packed it in, assuming I was probably only hundreds of a second slower than 3rd place.
We all got into Impound and they started weighing and dyno'ing a selection of cars. I was eventually weighed and was still 40 pounds heavy. Before they could finish with all of us, were told to leave our cars and head to the trophy ceremony.
NASA did a great job and each podium finisher in every racing class got champagne, a trophy, pictures with the Toyo Girls, and many of the contingency winnings were handed out right there. GoPro 3 Black edition cameras (just for running stickers), cases of Royal Purple, driving suits, and on and on. Time Trial had some of the more lucrative payouts, surprisingly. Mayfield had arm fulls of goodies and he had a smile a mile wide. Big congrats to him for the win and TT3 track record at Miller in his first time to NASA Nationals. It was close, with his final TT session 9 time dropping to a 2:03.052, and Smith in second only 3 tenths back at a 2:03.328 from earlier in the week. Nagel rounded out the podium in 3rd.
Left: The Official TT Final Results. Right: Nagels car sitting in Impound awaiting a ruling, after blowing the dyno. Twice.
But the fat lady hadn't sung her song just yet. After the trophy ceremony we headed back to Impound and the cars awaiting dyno runs and weight checks stuck around until our cars were released. Mayfield's BMW dyno'd clean and went to load up. Nagel's white M3 got weighed and dyno'd since he was in the top 3, which was apparently that car's first trip onto the rollers all week. But it blew the claimed maximum power number on the dyno by nearly 10 whp. They did the 3 pulls and then his team argued about the shape of the dyno graph on one of the first pulls. So they pulled it around in line, got it up on the trailer, strapped it down and dyno'd it again, 3 more pulls. Ryan watched the second set of pulls and it failed again. Meanwhile I'm drinking a few beers and just hanging out at Impound, awaiting the outcome. Several TT directors met, they checked his most recent weight and dyno numbers, recalculated his class ratio, and it was also over the limit. Hmm....
The National TT Director Greg Greenbaum was busy with a protest and an appeal from another class entry (Super Touring Corvette) that took over an hour. After that was decided (it went all the way to an Executive Appeal and a NASA Board of Directors), he came to decide what to do with Nagel's dyno issues. Apparently since it blew both the dyno and ratio, all times back to a previous good dyno were to be thrown out. And since he didn't volunteer or have another a clean dyno earlier in the week, there was nothing to fall back on that was legal, so all of his times were tossed. If the ratio had still been good (power to weight) it would have just been a session DQ, which was already a DQ for the spin anyway, and he would have held onto 3rd. Greenbaum said "yep, he's DQ'd for the entire week, you are now 3rd place". Yep, just like that.
I talked to Nagel, and he was rather cool about it "Hey, I don't tune it, I just drive it". We shook hands, he congratulated me, then he went and got the 3rd place trophy out of his trailer and handed it to me. Man, that was rough - I felt so bad for him.... but not bad enough that I didn't take that trophy! Does an inherited win feel as good? Heck yes, when the cars were thousandths of a second apart and the other car didn't make dyno. We worked our asses off all year, and built a heck of a good TT3 car, that was both quick and legal. It was also a street legal car, with A/C, emissions, tags, interior, NAV/radio, the works. Weren't too many (any?) of those on the podium that week in any TT class. Probably for a reason!
Left: One of the TT Directors congratulates me on 3rd place. Right: It wasn't a podium ceremony, but I'll take it,
While I was awaiting the Impound ruling, Amy, Ryan and Brandon had pulled the front end off, loaded up the car, got the 21 tires with only a qualifying run I scavenged from Hoosier's trash pile secured, and we rolled out for our 2 day/25 hour return trip around 6 pm, with Ryan and Brandon with us for the return trip. These Hoosier scrubs will keep us in R compounds for HPDE and test laps for months to come!
Wanted to give a shout out to our paddock mates from Minnesota. These guys are part of a ChumpCar team that were at Nationals to support one of their driver's, who ran some World Challenge races in the past and was now running a Honda Challenge Civic in PTC (should have been PTD - long story). These guys have been friends for years and were having a lot of fun. Photographer Brian Smyer was hanging around with this crew, too.
At right is the Best Team Photo.. EVAR!
continued below
Fair is offline
Old 09-30-2013, 04:13 PM   #223
Fair
What Did We Learn At Nationals?
Reflecting back on this Nationals week, heck, this last year of running TT in NASA, we have learned a lot of lessons, and I'm sure we have many more to still learn. The experience of going to NASA Nationals was both informative and fun for our entire crew - and even the guys at the shop who didn't join us there. Coming home with a trophy was a good feeling, especially after starting the week off so slow and so far back (the car got 5.3 seconds faster from Thursday to Sunday).
Here are some of the little bits of wisdom that I humbly share with you after this Nationals experience:
  • The power to weight ratios in TT's numbered classes are better explained in the ST rules. Most people were cheating themselves, running too much weight or too little power until the TT directors got us straightened out. Yes, even at Nationals, mistakes were often made on classing sheets.
  • Don't run 40-60 pounds heavy for your class then complain if you lose by .017 seconds. In NASA, the power and weight matter a lot.
  • Don't fear the dyno - get a dyno test done AT Nationals on the OFFICIAL dyno early in the week. Ask for a weight check early and often, too. You will want to have a good "tested legal" date to fall back on, in case a later test is blown.
  • High altitude tracks can produce funky dyno numbers - be prepared to have to de-tune or add weight when the conditions are very different from your home track.
  • There is no substitute for fresh race tires. Ever. The normal tire strategies we use at Regional NASA events (R6s for most of the laps, A6 for a single session and faster hot lap) can work well, but at Nationals we needed more sticker sets. Showing up on used or worn tires was a big mistake, as we were partially tuning around bad tires. Neal Roberts had taught us this. Economics got the better of us.
  • Making huge changes to the car or set-up right before Nationals is a bad idea. Pick a time period a month or two before Nationals and LOCK DOWN YOUR SET-UP. Don't count on the 4 days of TT sessions to help fine tune the set-up, either.
  • Don't skimp on your trailer tires. On an enclosed 2 or 3 axle trailer, bring two mounted spares plus at least a third unmounted spare trailer tire. Keep one spare + the axle lift ramp + a proper lug wrench right next to the trailer side door for easy access.
  • Towing over the Rocky Mountains is the suck, no matter what vehicle you are using. Going "around" the mountains is easier than going over the worst passes. Plan your route accordingly. On the return trip we heard of some folks seeing ice on the roads on the difficult passes.
  • If you are going to Nationals and have never run the track before, get there at least a day early to practice. Budget for this with time and tires.
  • If you have doubts about fuel availability or quality at the track, bring your own fuel. We spent a small fortune on 100 octane race fuel to mix with the 91 octane "Premium" they use in Utah.
  • When it comes to numbered TT classes (TTU/1/2/3), don't skimp on the aero. EVERY SINGLE top TT3 car had excellent wings, splitters, and low drag tricks. Nobody in TT3 used the "better" 9:1 optional ratio for using stock aero... every fast car took the weight hit to use aftermarket aero.
  • Too much front downforce can be a bad thing (we've since made a 2nd splitter that is 4" shorter - see my next event write-up on how that worked).
  • Don't do your aero set-up testing at a track that only has low speed corners (duh).
  • High speed tracks require SERIOUS braking systems. Don't skimp, and "bigger is better" applies.
  • Don't bring a street car to run in the top TT classes at Nationals and expect to win. It might work at a Region level, and it might have worked at Nationals in the past, but the top guys show up to Nationals in serious race cars.
I hope our mistakes and experiences can help you make the right choices for your TT build, if and when you decide to try your hand at this sport. And I hope reading our posts encourages that goal for most HPDE folks. Why? Because after a while just "running a DE" can get boring. There are not rules, times, or competition to drive you. Just "driving around a track" doesn't teach you much, once you have gone through instruction and are Solo'd. We've seen a lot of HPDE drivers moving towards TT, and I think that is great. But don't assume you have to go W2W racing after you get to TT. Many of us don't want or need the added risks, costs and damage potential that W2W racing has. If you can afford to write off your car after some asshat punts you off track and destroys your car, and that won't upset you too badly, then by all means... go right ahead. Because that can and does happen in W2W, but not in TT.
Hard Choices - Selling BOTH Mustangs?
Unfortunately we still need to sell the 2013 GT, and it has taken so long now that I'm forced to put the 2011 GT up for sale now, too. I know, that sucks - trust me, I don't want to do this. We had planned on selling the 2011 at the end of this year or in the Spring of 2014, to make room for the all new 2015 Mustang we want to buy, prep and race in 2014. That is still happening, but with so much $$$ tied up in both Mustangs, I need to move them sooner rather than later. We had hoped we could keep the red car for a while longer, but expanding the business needs cash right now and both of our S197 projects are going on the auction block. Look for an updated ad for the 2013 GT and a new for sale ad for the 2011 GT soon.
continued below
Fair is offline
Old 09-30-2013, 04:14 PM   #224
Fair
continued from above
Since nobody made a serious offer on it, our black 2013 GT is getting taken back to stock very soon and will likely be sold on CraigsList to some random schmuck, as the "track ready" set-up didn't get me any legit buyers (just a couple of fast talking con men and a few low ball pranksters). Our red 2011 GT will be posted up as it sits in TT3 trim now, with the aero front end and one set of 18x12" wheels and tires. If that is a bust we'll put it back to nearly stock and sell it that way, too. Don't PM me about parts off of either car just yet, as I will ignore those straight off. When/if these cars have parts pulled off they will go for sale all at once and I'll post an ad here.
What's Next?
There are still a lot of events we might be able to squeeze in with the red 2011 GT. And who knows? Maybe the 2013 GT will sell and some other things will fall into place and we won't have to sell the red GT right away, and I can make all of these events (fingers crossed!). Here's what is on the race schedule for the next few weeks.
  • NASA @ TWS on Sept 21-22 - we've completed this event and I will have the write-up shortly.
  • Camaro Vs Mustang Battle on Oct 5 @ Texas Motorplex - sign up here. Vorshlag is putting together the autocross portion, so if you have a GM or Ford powered vehicle, please come out and join us. Only $45 to both autocross and drag race, and we will make sure it is going to be fun!
  • Goodguys Lone Star Nationals Oct 4-6th @ TMS - We will go to this on Sunday Oct 6th for the Autocross (the last Optima Qualifier for 2013) in the red car on whatever street tires we can scrounge up. Any American built or American powered vehicle is eligible.
  • SCCA Autocross @ TMS Road Course Oct 13 - if we still have the red Mustang by then we will run this event in that car. This is their once-a-year "road course" event, with the infield road course at Texas Motor Speedway lined with some cones and packed with a bunch of autocrossers. Walls beware!
  • NASA @ ECR Nov 2-3 - Again, assuming we still have a TT3 car to race by then, we will be there trying to finish out the NASA Texas calendar with a 100% track record sweep in TT3 for 2013. We're 7 for 7 so far....
2015 Mustang for 2014 in... TT2?
So to recap a few of our 2014 plans, we plan on buying one of the all-new 2015 Mustang GT's as soon as it is available. From talking to a few key people that have sources at Ford, we think the new S550 chassis is going to be at least 100 pounds lighter. The Coyote 5.0 engine choice is assumed to carry over, and if it is like previous "chassis changes" it will likely have a small power bump, too. We will get the V8, manual transmission, and likely red again - but that's it. I'm not letting Amy pimp this one out with a bunch of options. So this means it will be even lighter and more powerful than the 2011 GT which we have been playing with in TT3, so we'd have to cork up the engine and/or slap on a bunch of extra weight to stay within the 9.5:1 pounds per hp ratio of TT3 class "with aero".
The next class up the Time Trials ladder is TT2, which has an 8:1 ratio. We have extrapolated that this S550 will likely end up there, once we upgrade the suspension, wheels/tires, and aero like we have the 2011 (and that will happen quickly). So TT2 is what we are shooting to run next year, again with a goal of developing new parts for this new Mustang chassis (S550), and hopefully racking up a few more NASA TT track records along the way. We haven't found a better venue to test new products for a car than the competition that NASA Time Trial provides. Unfortunately the NASA Texas the season starts in January, and the new car might not be out until April or May... and we had the TT3 regional championship for 2013 wrapped up by May of this year, so we can't wait that long to get a race car built.
Some of you may already know that Vorshlag is a lot more than just a "Mustang suspension shop". One of the many series of products we have developed over the years is our LS1 V8 swaps into various BMW chassis. We've done E30, E36, E46, Z3 BMW swaps and have kits for most of those, plus a V8 Miata kit that is under development. Our service shop has been cranking out a lot of BMW V8 swaps of late and I have a couple of E36 donor chassis at my house right now, without a clear purpose. So....
Vorshlag TT2/ST2 E36 Build Thread: http://www.vorshlag.com/forums/showthread.php?t=8254
Over the winter we will be building a TT2/ST2 BMW E36 LS1. The chassis is a white 1992 325is "E36 Coupe", with a tired motor and interior. This will be stripped down, caged, flared, painted and built into a W2W race car. We might briefly run it in TT2 before we sell it, too - that's my goal if we do end up selling the red 2011 GT before the new 2015 GT arrives.
Above: Our TT2/ST2 build is already underway with the BMW E36 chassis being stripped and readied for a cage
I know, its not a Mustang, but it will allow us to at least get in the class with something while we await the S550's introduction. We will also be building our E46 LS1 Alpha car with a 5.7L motor around TT1 class rules, also over the winter, which we plan to race and develop that kit with as well. The Alpha LS1 Miata that is moving forward (customer car), among other builds in our shop.
Don't worry - we're not done developing S197 parts, not hardly. Lots of S197 Mustang race prep, development and upgrades are still going on at Vorshlag on a daily basis. And we might be able to hang onto the red GT for a while, or if it is sold in "near stock form" I will look for a front damaged '11-14 GT as soon as we can and transfer over the front sheet metal and aero updates from this car, as well as some new shock and suspension options we are working on for this chassis.
So I hope this last series of posts wasn't too long and boring, and I apologize that my "Nationals Event Coverage" spanned so many days and too many words. I've already started my write-up for the TWS event on Sept 21-22nd, where the car again did very well. There was a host of updates done to the car before we took it to Texas World Speedway for this NASA race weekend, including a new "shorter" splitter which balanced out the aero imbalance we had at Miller. Our painter also reworked the hood and it looks top notch, but we lost the vinyl stripes in the process. I'll get that update posted shortly. Until next time...
Thanks for reading,
Former site sponsor
Fair is offline
Old 10-03-2013, 05:45 PM   #225
Bearded Banger
Bearded Banger's Avatar
I love your write ups!
Bearded Banger is offline
