Old 09-06-2013, 06:35 PM   #1
crowley
Default 2013 GT500 suspension install? Who have you used?
Just wondering what shop in the area people have used for suspension component installs. I'd be looking to get the following installed on my 2013 GT500:
Rear Suspension parts:
BMR Upper Control Arm Mount
BMR Adjustable Upper Control Arm
BMR Adjustable Panhard Bar
BMR Panhard Support Rod
BMR Lower Control Arm Relocation Brackets
BMR Single Adjustable Lower Control Arms
Front and Rear Springs:
Ford Racing M-5300-L Springs
thanks,
Crowley
crowley is offline   Reply With Quote
Old 09-06-2013, 07:47 PM   #2
BlueBolt
I use truestreet but vorshlag could probably hook you up too if you don't want to do it yourself.
BlueBolt is offline   Reply With Quote
Old 09-06-2013, 08:11 PM   #3
I have installed everything but the UCA stuff myself. I have done mine, josh, don, and Dale M. If you want to try and tackle it without paying a shop I can help you out. If you set on a shop, TS or Vorshlag is who I would recomend
Old 09-06-2013, 09:04 PM   #4
crowley
Thanks all. I have a quote from Truestreet and I know they do good work, so just shopping around for prices right now as Truestreet is about $200 more than I was figuring as they quoted $700. On the other hand, they are in my back yard so that makes it nice
Crowley
Old 09-06-2013, 09:30 PM   #5
TrueStreetTim
TrueStreetTim's Avatar
Crowley
Are any of your relocations weld-on?
TrueStreetTim is offline   Reply With Quote
Old 09-06-2013, 11:03 PM   #6
crowley
I believe it is all bolt on (with the option to weld). This is the package that revan racing put together and they mention unless doing some serious drag / road racing that you won't need to weld them (they didn't for the year they have had these parts on their GT500 and all is well). This is my daily driver which may see a few times a year the 1/4 mile and road racing.
Below is the quote from Van over there:
The only component that would need welding would be the relocation brackets. Is it necessary? Only if you plan on doing a lot of heavy drag racing. If it's simply for street driving I wouldn't worry about welding them in. Now if you want total peace of mind, then go ahead and weld them in.
Mine are still bolted in.
Honestly though, I would look to experts to guide me in this matter since this is my daily driver.
thanks,
Crowley
Old 09-07-2013, 10:11 AM   #7
TrueStreetTim
It's our opinion that welding them is best for any circumstance. It costs a bit extra in time, but bolts loosen/flex etc. therefore we weld 95% of our installs unless otherwise specified by the customer. Hope this helps!
Old 09-07-2013, 12:03 PM   #8
csamsh
I managed to bend my rear LCA pickup points using BMR brackets with stock power. I would get them welded.
2012 GT- Brembos, 3.55's
AST 4150's, Hyperco 550F/250R springs, Torsen T2R, Vorshlag CC plates, Whiteline Sways,
18x11 Forgestar F14's
csamsh is offline   Reply With Quote
Old 09-07-2013, 12:08 PM   #9
crowley
Thanks Tim! Are there any disadvantages to having them welded in?
thanks,
Gary
Old 09-07-2013, 12:20 PM   #10
TrueStreetMotorSports.com
This happens more times than not, Welding them is the only way I would want them on my car
thanks,
Gary
If for some reason you wanted to remove them there will be some extra time to cut and grind the welds off.
True Street MotorSports
901 N McDonald St Suite 100
McKinney TX 75069
972.542.9886
TrueStreetMotorSports.com is offline   Reply With Quote
Old 09-07-2013, 01:40 PM   #11
crowley
Thanks for the info guys
Crowley
Old 09-07-2013, 02:33 PM   #12
Crowley
Anytime
McKinney TX 75069
972.542.9886
