06-18-2013, 04:01 PM
FRPP P Springs
I've got a set laying around my apt waiting to get put on when I get my rims and tires put on too. Is there anything else I need to do with just swapping the springs?
06-18-2013, 04:17 PM
A panhard bar may be required to center the axle.
06-19-2013, 08:27 AM
If its in the budget new shocks and struts would improve the ride and handling as well.
2013- PW GT, MF street AB, AED tune, jlt cai,Lethal o/r x-pipe, gt500 spoiler, Barton bracket, koni yellows, ground control camber plates,steeda sport springs, whiteline PHB, whiteline sway bars,whiteline brackets, whiteline UCA & LCA, DSS driveshaft.
06-19-2013, 08:37 AM
My buddy at work told me that I should get a panhard bar.
06-19-2013, 09:05 AM
I've heard that the P springs aren't an aggressive enough drop to change the suspension geometery enough to recenter the rearend.
HOWEVER, I would definitely recommend it.
06-19-2013, 09:14 AM
I will invest in one. Better safe than sorry. Would hate to go through all that and then have the car leaning like it just had some purple drank.
06-19-2013, 09:32 AM
It won't really lean, just the rear axle may be slightly out of center, and you may notice one rear tire seems to stick out more than the other.
06-19-2013, 09:37 AM
I may have understood the effect incorrectly then. I was also advised to get some camber bolts for the alignment. Would you agree? For $20 seems like a safe and cheap bet.
06-19-2013, 09:44 AM
No problem. You probably won't need camber bolts, but those are also a better safe than sorry too. I lowered my car 1.25" up front and was still in spec for camber, but the adj bolts gave us a little more room for adjustment.
Caster/camber plates are truly the way to go to fix camber issues, but if your car will mainly see street driving, camber bolts will be plenty fine.
06-19-2013, 09:59 AM
FRPP P Springs
I needed camber bolts for my p springs on my 12 GT to keep my tire wear even.
06-19-2013, 10:05 AM
Thanks for the info
06-22-2013, 03:00 PM
front and rear?
06-22-2013, 03:18 PM
My car is lowered with BMR springs and I didn't need the camber bolts either. I have them sitting in a box in my garage. It's pretty easy to see how far off center the rear end is once it's lowered. If you wait about a week, there's bound to be 4th of July sales on parts. I'd suggest BMR, everything BMR on my car has been great and easy to install.
