05-19-2013, 10:11 AM
Clutch help
I have been tracking (1/8 mile) my car and last the last couple of times noticed some problems getting the car in third gear if I take the car to redline. I was running out of chances to run so I lowered my shift point to 6,000 and it went into 3rd fine. Do you think it's the transmission locking me out because I'm to close to redline? What is the fix, shift lower rpm or new clutch????
Thanks
J.Shoot
2013 Boss 302 #2602
D1 Procharger
So many mods I can't remember them all.
Built and Tuned by True Street
05-19-2013, 10:16 AM
Thanks
J.Shoot
I dont think the clutch is the problem. Could be the synchros in the tranny not keeping up and or wore.
05-19-2013, 10:32 AM
Re: Clutch help
There has been a number of people with this problem with the mt82. Check svtperformance there are some threads on it. Think one option is just to change the fluid, another would be an aftermarket shifter like Barton or mgw. I would do those before new clutch
05-19-2013, 10:47 AM
How would a shifter help? Wouldnt it make it worse since the shift will be quicker giving the synchro less time? Id change the fluid first.
05-19-2013, 10:56 AM
From what I've read, the consensus is shifter AND fluid. I haven't looked into it too deeply though, I've got a 6R80.
05-19-2013, 10:57 AM
BTW, what kind of times are you running, your car is making some good power.
05-19-2013, 12:27 PM
Re: Clutch help
From what I have heard the stock shifter and bracket have trouble going into third. I have never had an issue so can't say first hand
05-19-2013, 01:39 PM
Me either. Yet, if it had been fine then I cant see it being his problem. Plus, he said lowering the shift point made it go away? So that pretty much says its not a shifter prob.
05-19-2013, 01:49 PM
I would definitely change the fluid. If that does not help then look into a better clutch. At your power level and as much as you track it, a clutch will be very beneficial. If I remember correctly we installed an mgw shifter in this car.
05-19-2013, 01:50 PM
Also if you plan to track it often I would highly suggest flushing the brake system and the clutch fluid with motul 600 fluid as they both share the same canister.
05-19-2013, 02:08 PM
Changes so far.
I have changed to the MGW shifter already and changed the fluid last week, so no change.
My best time is a 7.11 @ 99 mph. I was launching at 4,000 rpm and hooking good. I tried to increase my launch rpm to 5,000 and the car breaks loose. I'm running 15" wheels with MT ET streets with 14-15 psi. I'm going to go back to 4,000. Maybe work up a little if it will hold.
2013 Boss 302 #2602
D1 Procharger
05-19-2013, 02:34 PM
Whats the limit on the stock clutch toby? I see varying numbers....
Did not know this.
Sounds more and more like tranny probs.
05-19-2013, 06:11 PM
I called the dealership where I bought it, they sound very willing to help and they no my car has been heavily modded.
Need to change the clutch also I think.
J.Shoot
2013 Boss 302 #2602
D1 Procharger
05-20-2013, 04:09 PM
Did not know this.
It does vary, but I would recommend changing if you are over 600 rwhp and plan to drive it hard often. I have seen bolt on cars blow the clutch and I have seen 800 rwhp cars holding on the stock clutch.
