Old 01-04-2013, 10:31 AM   #136
ProCharge5.0
I'm not doggin your build bro. The purpose of the thread was to get more current info on the Procharger systems. My experience with them hasn't been totally positive in the past, but everyone improves with time, well usually. lol.
I'm open to anything, I just like to do my research on anything I do before doing it.
From past experience, what usually happened is the Procharger didn't make the initial power as advertised just bolting on in stock form. You call back to tech to find out what's up, they start pushing add on sales with more pullies, more boost. You're already in $5k deep, might as well try to pulley it up, right? Then it ends up overspinning it, more heat and blowing out the seals in the headunit. A certain P1SC completely ate itself, broke the impellar and pieces blew back into the motor causing a complete failure. Very, very expensive mistake. Ouch..
So how do you know if you are over spinning a blower? I bought my P1
used and it came with the smaller pulley. The shop said it was fine so I didn't worry about it.
2011 Mustang 5.0. Brembo, JBA longtubes, H-pipe, Flowmaster Axleback, Procharger. 637rwhp, 499rwtq
ProCharge5.0 is offline   Reply With Quote
Old 01-04-2013, 10:46 AM   #137
TrueStreetTim
TrueStreetTim's Avatar
What size is your blower pulley? And I'm assuming it's the factory procharger crank pulley?
TrueStreetTim is offline   Reply With Quote
Old 01-04-2013, 11:05 AM   #138
I believe the formula is. Lower pulley diameter/top pulley= X engine rpm= X step up ratio= blower rpm
The max is written on your blower along with the step up ratio. Engine rpm would be where you shift at or the max rpm you want to run. Hope this helps
Old 01-04-2013, 12:46 PM   #139
Doug1227
Is this Clint? Doug from TFS here...
Old 01-04-2013, 01:08 PM   #140
TrueStreetTim
(Crank pulley size / Blower pulley size X step up ratio) X max rpm= impeller speed
Bold items are simply to separate the math
I'm assuming a lot here as I don't have all your specs. So your roughly 630whp? I'll also assume you've got headers & full exhaust?
P1SC-1's max impeller (max efficiency) speed is 65k. It should also be a 4.1 gear (step-up) ratio. Your blower pulley roughly a 3.60? And crank pulley a 7.5.
So [I](Crank pulley size / Blower pulley size x step up ratio) x max rpm= 61.5k impeller speed @ 7,200rpm. So your around 95% the max efficiency.
To see that kind of power on a P1 I'm guessing the car is around 12-14psi. What kind of psi are you seeing?
Old 01-04-2013, 02:00 PM   #141
Ok lower pulley is the crank but hey the math was right. I wasn't thinking when I wrote lower
Hey what's the stock crank pulley on a fox. I think it's a 6" but can't remember.
Old 01-04-2013, 02:07 PM   #142
ProCharge5.0
Hey Doug. Yep it's me
Old 01-04-2013, 02:18 PM   #143
TrueStreetTim
To clarify; the crank pulley in this scenario is in reference to the crank...blower...pulley. In other words...the one that comes with the kit for installation. So, yes, the "lower" is still correct lol
Old 01-04-2013, 02:28 PM   #144
I know which pulley is which. Just because I didn't write it out the way you would like doesn't make it wrong. I was also typing on a phone while taking a shit so give a fucker a break.
So what is the stock size crank pulley on a fox or does a cripple have to measure when he gets home.
Old 01-04-2013, 02:34 PM   #145
TrueStreetTim
Lmao, I wasn't throwing punches. Just letting you know that you were indeed correct and can continue your shit unstressed! The "clarification" was meant for others general knowledge. Sorry to confuse.
As for the fox pulley....I'm uncertain. The others might know. I'll see what I can find out unless you beat me to it.
Old 01-04-2013, 02:43 PM   #146
Lol I was just giving you shit. When I read it back after you did yours I knew it didn't make since. Yeah if you find out let me know. I think it is 6" but I can measure later if need be. I'm just trying to see where I'm at rpm wise myself.
Old 01-04-2013, 02:47 PM   #147
ProCharge5.0
The car has 1 7/8" JBA longtubes, H-pipe/ no cats, and axleback. I don't know what size the pulleys are. I will measure when I get home. It makes 10.5 psi. Car is stock other than exhaust and procharger.
Old 01-04-2013, 03:18 PM   #148
I hope Donnie rips that limp wristed gingers arm off. :-D
Old 01-04-2013, 03:30 PM   #149
I'm a lover not a fighter
Old 01-04-2013, 03:35 PM   #150
Ok, so go fuck his arm off then. Thats even worse! Lol
