11-21-2012, 07:48 PM
Broke down with the sales going on and bought myself an early Christmas present. Already done with the shopping for the wife and daughter so figured why not. And I already have lca's and brackets, just need to decide on shocks/struts.
11-21-2012, 08:00 PM
nice! and konis!
HPP TUNED HP-enough  4-0 vs Steve
11-21-2012, 08:17 PM
I'm still doing a little research on it, don't know if I want to switch to coilovers or not. Looks like plenty of guys are getting reasonable 60's with good shocks/struts.
11-21-2012, 08:19 PM
the 13 has d2 coilovers my 11 had the koni srts and they were great as well
03-17-2013, 04:53 PM
BMR lowering springs
BMR Adjustable Panhard Bar
BMR Panhard Bar Brace
BMR LCA relocation Brackets
BMR Poly LCAs
BMR Adjustable Poly UCA and Mount
Eibach camber bolts
I guess I like BMR products
Next upgrades coming when I have the cash, Konis, sway bars, and bumpsteer kit.
03-17-2013, 09:18 PM
Koni Yellow shocks/struts
Eibach Prokit springs
Eibach front/rear sway bars
J&M camber plates
J&M rear LCA
Considering adding:
Watts link
UCA
LCA relocation brackets
2011 Grabber Blue 5.0
03-20-2013, 04:41 AM
Re: Post your Suspension mods
Drag racing setup:
GT front springs
V6 rear springs
GT500 Strut Mounts
Strange adj struts (set on 5 for street and 0 at the track)
Strange adj shocks (set on 5 for the street and 2 at the track)
GT500/Brembo LCAs
BMR LCA relo brackets (set in top hole)
Roush nonadj UCA and Mount
Shelby rear sway bar
JPC rear sway bar relo brackets
No front sway bar
BMR Lightweight radiator support front sway bar delete
SPC adj panhard bar
03-20-2013, 08:22 AM
#23
Originally Posted by Yagermeister
Drag racing setup:
GT front springs
V6 rear springs
GT500 Strut Mounts
GT500/Brembo LCAs
No front sway bar
SPC adj panhard bar
I'm sure you've posted it somewhere before but what are the 60 ft times with that setup? And IIRC, you have 4.10's right?
03-20-2013, 09:17 AM
#24
Luke, Yes on the 4.10s. My car is an auto with a stock converter so my 60ft isn't what it could be compared to a manual but my best is a 1.77 in good weather this year
03-20-2013, 11:06 AM
#25
That's strong for an auto with a stock converter! Although, with 4.10s and a 4.17 1st gear, that's also a lot of mechanical leverage. Just curious, what tire is that? I'm assuming a 275/60 radial.
03-20-2013, 11:32 AM
#26
So when's the converter coming? I keep holding myself back from buying a 4C, the bug to go faster is an expensive bitch.
03-20-2013, 11:34 AM
#27
275/60/15 M/T ET Street Drag Radials
for the full list of mods: http://2011gtcs.weebly.com/
03-20-2013, 11:36 AM
#28
Longtubes and Driveshaft hopefully within a month and then a converter with around 4200 stall hopefully during the summer sometime. Have a friend who had gone 11.71 (just a hair slower than me with similar setup) and just installed a 5C (4200 stall) and went down to 11.15 instantly with a few more tweaks to the tune
03-20-2013, 11:52 AM
#29
I've considered the 5C as well, when the time comes I'll give him a call and get his recommendation. I picked up a D/S on an SVT group buy, it's actually getting sent back soon. Driving down the road I got a horrible vibration and it got so bad that even riding the brake the car would shake. Had to put the stock shaft back in til they check it out and send me a replacement.
03-20-2013, 12:24 PM
#30
My setup:
Tokico D-Spec adjustable shocks and struts (currently set to 4.5 turns front, 4.75 turns rear)
BMR SP009 springs
GT500 strut mounts
Eibach 1° camber bolts
Freedom Racing Aluminum Dbl Adj PHB
Next on the list will be LCAs or relo brackets.
