Old 07-03-2013, 06:22 PM   #1
Oxford14Stang
Oxford14Stang's Avatar
Default Eibach Sportline and OEM wheels
What's going on guys, quick question. I didn't think about it till a few seconds ago. I'm planning on ordering the sport lines and was wondering if I'll have any clearance issues on the stock 235/55/18s?
2014 Oxford White 5.0 MT-82
Oxford14Stang is offline   Reply With Quote
Old 07-03-2013, 07:06 PM   #2
no.
Old 07-03-2013, 07:19 PM   #3
Oxford14Stang
Okay, sweet. Thanks!
Old 07-03-2013, 07:22 PM   #4
Get an adjustable PH bar.
Old 07-03-2013, 10:40 PM   #5
Oxford14Stang
Will do. Will buy it all and install it all together. Thanks for the info guys
Old 07-04-2013, 09:20 AM   #6
kn7671
You can stuff quit a bit more tire under there before having to worry about clearance issues.
Do yourself a favor and get new struts and shocks with your springs. If you're gonna go that far into the car, the factory struts are already coming completely off, and the rear shocks are only two nuts from coming off.
The stock Ford Mustang GT shocks and struts suck donkey balls, and with stiffer springs, you will notice the shortcomings even more.
Virtually replacing them with anything is better than stock, though I prefer the Koni Sports (yellow) for adjustment preferences. You can go cheap or expensive with some KYB's or Koni STR.T's (orange), Eibach, Tokico HP or D-Spec, Koni Sports, QA1, or Bilstein.
2015 Mustang GT - Black w/Perf Package
kn7671 is offline   Reply With Quote
Old 07-04-2013, 09:36 AM   #7
Which of those would give the softest, factory like ride quality?
Old 07-04-2013, 11:18 AM   #8
Prolly the yellows on the softest setting
Old 07-04-2013, 04:46 PM   #9
Oxford14Stang
I will look into it for sure. At the moment I'm shy on the cash and can't stand looking at a "4x4 looking" mustang lol
Old 07-04-2013, 10:56 PM   #10
jayman33
Koni Str.t are currently 330 shipped but you'll need GT500 strut mounts M-18183-C which are 100 shipped. We also have the sportlines in stock. This setup along with a PHB will set you straight.
734-306-5231
Old 07-05-2013, 10:10 AM   #11
All of the adjustable shocks/struts have setting(s) that are softer than stock. If I turn mine all the way down it's like they're not even there.
Old 07-06-2013, 10:11 AM   #12
Oxford14Stang
Thanks, will look into it.
Old 07-08-2013, 12:10 PM   #13
Boomer
Like Jayman says, get these strut mounts! I ran these sportlines on my 2010 and the drop is pretty low. The GT500 strut mounts are thicker then OEM, the thickness of the mount helps reduce any popping the struts get from lowering the car. If you are on a tight budget and decide to go with new mounts only, I suggest some Eibach camber bolts. With the sportlines it will change your camber and without breaking the bank the camber bolts will help with the alignment, the amount of adjustment isn't as significant as camber plates but its better then nothing. These parts together are a good alternative if you are not going all out for caster/camber plates. On your stock wheels you will have plenty of clearance, I ran 245/45/19 up front with these springs and it would get a small amount of rubbing at the top of the wheel well. You should be fine with you're tire setup.
Boomer is offline   Reply With Quote
Old 07-08-2013, 03:46 PM   #14
Just turn the upper strut mount 180* (arrow facing in or out, I can't remember). You will eliminate ~1.5* of negative camber doing so.
Old 07-08-2013, 04:44 PM   #15
Oxford14Stang
Okay guys thanks for all the info. As for alignment goes our front end tech. At my dealership will be doing the alignment and the suspension work for me. That way it gets done while I'm at work and I can still make money
