Old 09-15-2013, 03:32 PM   #1
Rebelracer568
Rebelracer568's Avatar
Think im going to try some ra-1's they grip well and have pretty good life. My buddy at chicane 23 is the guy on tires
2014 sterling gray 5.0 mustang gt. MT82, 3.55 gears with few mods
1973 mercury comet 347ci Jerico 4 speed tranny
1978 mercury Capri 2.8l German v6
Rebelracer568 is offline   Reply With Quote
Old 09-17-2013, 03:56 PM   #2
Fair
Toyo makes some of the worst R compound tires around. Seriously - ask any racer who is stuck using them in a spec or tire spec'd class (CMC, AI, Spec Miata, etc). The only racers on Toyo tires are ones that have to be on Toyo tires. I have been labeled a "Toyo Hater" by some, and I was even tricked into buying a set of Toyo R1Rs on our Mustang (shown below). Horrible pieces of sh!t that had terrible grip and horrific wear. They were the slowest in our private tire test in May 2011.
The RA-1 makes about the exact same grip as many of the modern 140-180 treadwear "Extreme summer" tires but has worse wear. I've tested RA-1s back to back against Yokohamas, Bridgestones, Hankooks and others, with data logging and timing equipment, and they were not any faster in any measure except wear. We raced in Street Touring classes for years, and would often switch to R-compounds at events to see back-to-back differences. We tried RA-1 tires on 2 different occasions, but were faster on street tires. We have done many tire tests over the past decade. RA-1s are at the bottom of my "recommended tire list". The very very bottom.
Now, autocrossing comes down to two main things: weight and tires. For the most part you cannot lower weight from an S197 enough to make a radical difference in times. These are big, heavy cars, and we're pretty much stuck with 3400-3600# curb weights. But we can do something about tires. My advice: GO AS BIG AS YOU CAN AFFORD. You can never have too much tire in autocrossing, or tracking, in an S197.
The widest wheel that easily fits these cars front and rear is an 18x10, with the offset around +43 or so. Anything wider either A) doesn't fit or B) will need different front and rear offsets. And by "fit" I mean it fits under the stock fender contours. Vorshlag pioneered this fitment several years ago.
Kumho V710 R-compound tire in 315/35/18 on Forgestar F14 in 18x11" on 2013 GT, lowered 2.5"
One of the more popular set-ups we sell lately is an 18x11" Forgestar for $350/each. It is light, it is very wide, it is the proper diameter (18" - just big enough to clear the 14" brakes, and nothing more) and it fits under the stock fender contours with nothing more than a little negative camber up front. These will not rotate front to back and have significantly different offsets on each axle.
305/650/18 Continental Slicks on a 11" forgestar F14
These 11" wide wheels will work well with a 285 to 315mm wide tire. One of the popular sizes to use with it is the 295/35/18, and another is a 315/35/18. Not a ton of choices in those two sizes, but there are some good ones.
http://vorshlag.smugmug.com/Projects...heel-teesting/
The gallery above shows some of the wheel and tire testing we've done on S197s. Dozens of different wheel brands and widths we have tested, including wheels we had custom built to fit these cars. That 18x10 ET43 came from us, on a run of wheels we made 100 of to get them out there, which everyone later copied.
We've stepped up to a 18x12" wheel on both ends on our TT3 Time Trial Mustang, and flared the fronts for use with up to a 335mm tire. We usually still run on 315/30/18 Hoosier R6 or A6 tires, though, as they are much more common and easier to get. Plenty of grip. For a mostly street car I'd use a ~180-200 treadwear 275/40/18 on an 18x10" and be happy.
Note: the 18x10 "drift" wheel is a cheap and super heavy wheel that is shunned from virtually all S197 racers. Absolute boat anchor wheels... but they are super cheap, so street guys flock to them. Not racers - way too heavy. Adding rotating inertia like this is extremely detrimental to competition use.
Cheers,
Former site sponsor
Fair is offline   Reply With Quote
Old 09-17-2013, 05:49 PM   #3
Rebelracer568
Cheers,
Not planning on do competion just track days. Cant afford 4000 in rims and tires just doesnt seem worth it when I can spend 900 for tires and 600 on rims. Heavy yes but for occasional fun thats all that matters. I want the bfg rivels and contacted yall several times on em. Never got a response
Old 09-17-2013, 06:18 PM   #4
modernbeat
modernbeat's Avatar
Hmmm, is your name Lagace? That's the only person that's contacted us regarding Rivals on a Mustang. And we sent that fellow a quote. If that's not you, try contacting us at [email protected].
The 18x10 D-Force are only $309 each. BFG Rival tires are moderately priced for the size at $290 for the 295/35/18 tires. Tirerack lists tires in that size from $236 to $432. That $2396 for damn good tires on lightweight wheels.
Jason McDaniel at Vorshlag Motorsports
modernbeat is offline   Reply With Quote
Old 09-17-2013, 07:04 PM   #5
bird_dog0347
Would you recommend using those on a daily driver? I'd like to do an autocross event or two but my car is a stock 2014 GT and is my daily driver. I plan to do some mild updates to the suspension but it'll never be my full blown "track car". I do have a 92 5.0 notchback that I'm installing an 04 Cobra IRS on and will be going full coilover as well with poly and derlin bushings and eventually I'll take that to auto-x and track days. I'm sure though given the suspension mods I've done I'll never be competitive in the class I'll be forced to run but so long as I improve every time out I don't really care about winning against guys with more money and less kids.
In the mean time, I'll be looking for different tires/wheels for the '14 and wouldn't mind some recomendations that A.) won't break the bank and B.) won't make me buy tires every 10k miles.
bird_dog0347 is offline   Reply With Quote
