06-15-2013, 11:02 AM
Re: cat less
Originally Posted by Selcouth
Simple way around that. Purchase a catalytic converter that has a straight pipe running through it.
Has the looks of a catalytic converter, but its technically not.
This.
You could always fab up some heat shields or run gutted ones.
06-19-2013, 10:10 AM
Originally Posted by JDMLOL
This.
You can find shops that will gladly do this for you, especially if they have cars in local drag racing competitions
06-19-2013, 07:39 AM
Svt performance actually did a test on the 2011 gt and 19 horse is gained on the dyno by killing the cats.. I'm sorry the the best bang for the buck there is. Wait I just looked that's 19 with an X pipe the H pipe is 3 less.. still a bargain ... all I need is a take off set of gt500 mufflers.. someone can have my flow master axle back as trade!! Ha ha
06-23-2013, 03:38 PM
Yep, when you order your tune they should ask you , if not then just ask them to turn off the rear o2 sensors
06-23-2013, 05:18 PM
Speaking of catless, anybody ever dealt with cat delete pipes? I've heard some have had fitment issues.
06-23-2013, 06:15 PM
I know you can turn off the rear o2's but come inspection time the system will show not ready. There is a way to get around that on the Ls cars with hptuners but I had not heard of it with the 5.0's and SCT yet.
Don't get the bbk's. I bought them and the coupling was too big so they leaked. If you don't mind welding them its not a big deal. I haven't heard of any complaints with the jegs cat deletes.
2013 5.0 A6:
06-25-2013, 08:13 PM
On the LSx based cars it was simple, O2 Sims which were basically just a resistor attached to the connector end of the O2 sensor that you plugged in and zip tied out of the way
I am still trying to find a way to run catless on my 5.0 and not have to worry about inspection shit. It got REALLY expensive on my Trans Am once I did enough work that they KNEW it was catless without codes thrown or visual
06-25-2013, 09:05 PM
I have been doing some research on cat deletes and have read numerous times that bbk's have fitment issues. Now I have heard good things about steeda's cat deletes. Plus they come with "O2 sensor provisions", whatever that means. Pretty good price too for a 11-14 rwhp increase. Here is the link http://www.steeda.com/store/steeda-2...ete-pipes.html When or if I get a 5.0 I'd definitely purchase these bad boys.
04-23-2014, 03:16 PM
I bought the jeg's cat deletes. Bolted in easy and no leaks. even after i heat cycled them a bunch and rechecked the bolts. still no leaks.
06-24-2013, 07:27 AM
The system shows not ready only if you recently tuned it and there are not enough hours of run time, that's to prevent you from turning off a code then heading to inspection, as for the pipes, I've heard good things about jegs also
06-25-2013, 01:43 PM
Buy the BBK h-pipe and cat deletes. When it comes time for inspection, put your cats back on.
2011 GT 5.0L Auto
GT500 Mufflers | Lethal O/R H-Pipe | JLT Intake | UPR Products 91 Tune | Koni shocks/struts | STEEDA springs | UPR tubular lower control arms | PHB
12.76 at 113mph, 2.07 60' on stock tires
06-25-2013, 08:16 PM
According to my scanner, my o2 sensors and heater show not ready and I've been running this tune for several weeks and at least 500+ miles. Does it depend on the tune?
06-26-2013, 07:04 AM
#13
Hmmm it might depend on the tune... I know many guys running cat less that showed me, no cats, no codes, and just inspected, and I called bama and they told me no problem unless they look under the car, it will pass inspection
04-23-2014, 02:20 PM
#14
Where would you buy high flow cats that have pipes through them?
04-23-2014, 02:31 PM
#15
Just drive it with an expired sticker....with all that power gain you can outrun them..lmao
2012 Mustang GT - replaced motor mounts with yarn
2011 CTS-V COUPE - Added a wife
