Old 05-09-2013, 03:11 AM   #1
downtime!
downtime!'s Avatar
I'll put another vote in for VMP's mail order stuff. Justin's canned tune on my car ran 12 flats at 117 with muffler deletes and dr's. That said, and as good as his mail order stuff is, there is still no substitute for a hands on custom tune by a skilled tuner.
Old 05-09-2013, 08:13 AM   #2
moostang09
moostang09's Avatar
Default BAMA Ghost Cam Tune, GOOD OR BAD?
I heard from a buddy that the only issue that a ghost cam tune can cause is a need to change out spark plugs a little more often. Just bc of extended periods of idle time like sitting in rush hour traffic.
Any truth to that?
www.youtube.com/moostang09
moostang09 is offline   Reply With Quote
Old 05-09-2013, 10:01 AM   #3
Any truth to that?
Yes. It's due to all of the unburned fuel from the car running really fat.
Old 05-09-2013, 10:02 AM   #4
BTW, Mike Wilson is not even at Bama anymore and hasn't been for awhile. He is back here in DFW and like usual Bama's shady business practices they are still using his names for their tunes even though he's not there.
Old 05-09-2013, 10:05 AM   #5
Fake cams ftl
Old 05-09-2013, 06:07 PM   #6
JDMLOL
JDMLOL's Avatar
Default Re: BAMA Ghost Cam Tune, GOOD OR BAD?
I'm a little ignorant on cams, but do they even make decent cams for these motors? All I've seen for these cars are nsr cams and I would think they couldn't add much if the lift isn't enough to require new springs... is lift even the right term for a dohc??
Old 05-09-2013, 06:26 PM   #7
kanetrain
kanetrain's Avatar
Maybe this is pure ignorance on my part, but why do you guys consider it "fake"? Isn't it the cams making that sound?? I understand it's just an idle thing, but I don't think I would consider it "fake" if it is, in fact, the cams making it make that sound.
Eibach coil over kit, adjustable panhard bar w/ rear LCAs, Hurst shifter, magnaflow cat-back exhaust, o/r x-pipe, 85mm tb, cai, tune, 3.73 rear end gears, gold plated cross drilled/slotted rotors, TSW 19inch wheels, nice big 305s on the rear.
kanetrain is offline   Reply With Quote
Old 05-09-2013, 06:59 PM   #8
Smurf50
Smurf50's Avatar
With a "ghost cam" tune, you don't actually have aftermarket cams with a different LSA causing the "loping" sound. It's purely done with variables and causing the car to run very rich
Smurf50 is offline   Reply With Quote
Old 05-09-2013, 08:03 PM   #9
kanetrain
kanetrain's Avatar
Well of course they aren't "aftermarket", but it's still the camshaft's lobes making the "lope" correct? I know they dump fuel into it, as well, but it's the lobes that are making the sound?? I may be wrong, I'm curious.
Old 05-09-2013, 08:24 PM   #10
Smurf50
Smurf50's Avatar
Incorrect. The sound of a car "loping" is due to the grind of the camshaft and the LSA of that camshaft. On a stock grind the idle will be smooth, such as if you remove the "ghost tune" from the car. All it's doing is tricking the car into dumping excess fuel, adjusting the timing and the lift electronically to simulate the cam lope.
Old 05-09-2013, 09:57 PM   #11
Toby
With the new 5.0 they have electronic solenoids that act with the oil pressure and a spring on the cam sprocket to adjust the Lsa. The intake and exhaust have their own separate solenoid and galleys to where each can be adjusted how ever and what ever you want, you just need the correct software that gives you access to these tables in the tune. With the factory setup the computer can advance or retard the Lsa as much as 50*!! With the ghost tune it simply advances the cam timing thus causing the lope sound. When installed "straight" up the factory cams would be some choppy mo fo's!!!
Old 05-09-2013, 10:12 PM   #12
Pepperinyoureye
Pepperinyoureye's Avatar
My Bama tuner/tunes just came in on Tuesday. Been on Race tune since then and I'm satisfied so far. Much smoother power band, throttle response is great, and like stock drive ability. Cant really speak on the cam tune but I'm happy so far.
Pepperinyoureye is offline   Reply With Quote
Old 05-09-2013, 10:45 PM   #13
JDMLOL
JDMLOL's Avatar
I just got mine today. Happy so far, may do the dyno thing when im settled on mods for a bit. Anyone have a little longer crank time on the first initial start up after loading the tune? Im assuming because the key is on and the fuel pump is ready to go for so long when loading...
Old 05-10-2013, 10:13 PM   #14
The more I hear about the coyote motor the more it seems like a kseries motor from Honda. It to can adjust timing up to 50degrees! Man I guess we should be thanking Honda for variable valve timing in a way.
Old 05-10-2013, 10:42 PM   #15
Selcouth
Selcouth's Avatar
Uh oh you just went there.
Selcouth is offline   Reply With Quote
