Lower your Mustang easily with Performance Package by BMR Suspension!
Whether you're looking to replace worn out or damaged factory springs, or want to upgrade your Mustang's suspension with performance-enhancing aftermarket lowering springs, Koni Handling Performance Package by BMR will be your best bet. Designed to improve the ride quality and handling while maintaining the renowned Koni quality performance and looks, this kit has everything to complete the job. It allows you to lower your stance for that aggressive looks, and get a perfect blend of great performance, aesthetics, and ride comfort. This kit includes rear lowering coilover springs, rear shock absorbers, front shock absorbers, and absorber kit. It is 100-percent bolt-on and requires zero cutting, welding, or modifications to the chassis or suspension. BMR Suspension® - Koni Handling Performance Package https://images.carid.com/bmr-suspens...ms/khp006r.jpg https://images.carid.com/bmr-suspens...s/sp009r-2.jpg https://images.carid.com/bmr-suspens...s/sp009r-3.jpg https://images.carid.com/bmr-suspens...s/sp009r-5.jpg https://images.carid.com/bmr-suspens...s/sp009r-4.jpg Features: - 100% Bolt-on - Specific combination of parts - Fully street and track tested - Greatly improves handling - Adjustable and non-adjustable components - Heavy-Duty construction - Durable powdercoat finish - 5-6 hour installation time View the complete selection of BMR Suspension Products for Ford Mustang https://www.carid.com/bmr-suspension/ Lower your Mustang and improve the handling with BMR Suspension - Koni Performance Package! |
