Mustang Air Lift Performance Suspension
AirLift Performance Suspension's 2005-2014 Mustang air ride digital suspension kit allows you to fine tune your S197 suspension at any time. Featuring 30 way adjustable struts and shocks and progressive rate, tapered sleeve rear springs, this kit is the ultimate performance suspension kit. These kits allows you to slam your Mustang to the ground at the push of a button with over 4" of drop in the front and rear. With the ability to lower or raise you car within seconds, you can easily make much needed adjustments at the track or on the street for performance and clearance issues.
Just click the banner below to check it out: http://1115795f3e80f37d130b-0f74453f...nsion_6572.jpg |
