-   -   Battery Died Again WTF (http://www.dfw50s.com/showthread.php?t=3124)
Dominic Toretto 11-14-2013 05:04 PM
Battery died a few months after getting it. Don't have the receipt right now but couldn't have been more than 5k miles ago so I got a new battery from Ford. Now it's at work again clicking and won't turn over. Another dead battery wtf? Neither times was anything left on to draw power from the electrical system. Ideas?
Dan12GT 11-14-2013 05:07 PM
Test your alternator.
03MachMe 11-14-2013 05:26 PM
Prolly a drain somewhere. Do you have aftermarket stereo or anything else electronic?
Dominic Toretto 11-14-2013 05:27 PM
Will do. Perhaps this weekend if the problem persists.
Nothing electrical aftermarket.
kdanner 11-14-2013 05:35 PM
Seems common with these cars. Motorcraft batteries were always really good. Wonder if they changed suppliers, or it is just this one size.
Dominic Toretto 11-14-2013 05:45 PM
Guess a yellow top is going to be purchased sooner rather than later:lewx4:.
kdanner 11-14-2013 06:02 PM
Mine is weak and I need to do something soon too. I want something light with good capacity, but cringe at the idea of a $1500 battery.
McNastyGT 11-14-2013 06:47 PM
Parasitic drain...look for a light or anything small that is staying on. Highly doubt it's the alternator
McNastyGT 11-14-2013 06:50 PM
You can easily check the alternator with a dmm just start the car and put the leads on the positive cable and a good ground you should be getting 14+ v at the battery
Dominic Toretto 11-14-2013 07:31 PM
Good God man, what kind of battery are you buying for that much money?
Just left O'Reilly's. Battery, alternator and starter all checking out fine. Really not sure what I could be leaving on.
McNastyGT 11-14-2013 07:33 PM
It could be something as small as a trunk light...make sure everything is shut good if it still does it you should have a parasitic draw test done on it and make sure that's not the problem
kdanner 11-14-2013 07:39 PM
The lithiums are high.
http://www.summitracing.com/parts/lpp-l3400/overview/
McNastyGT 11-14-2013 07:40 PM
For the draw test you need a dmm and amp clamp. Put the amp clamp on the battery positive cable with the arrow pointed towards the battery and let it sit for 30 min or so and come back the reading shouldn't be more than .2-.7 amps
Dominic Toretto 11-14-2013 07:42 PM
I may have overlooked something earlier. I do eat in my car on lunch.
Originally Posted by kdanner (Post 56503)
.... no.
five.slow 11-14-2013 09:52 PM
It's not the alternator... A light will be on telling you it's not charging. Mine factory battery didn't lady 1000 miles and it was done. Since the new battery I haven't had an issue.
