Need a favor: does anyone have..
Does anyone have some stock injectors laying around that I could temporarily borrow? I'd appreciate the favor if you can help out. :)
i have some...when do you need them?
What do you need stock injectors for
Are you sending out your stockers to be reflowed higher? If so what is the end flow rate and how much?
Thanks again to Jeff for the headers and injectors. David says he has the intake manifold so i should be all set after that!
